Author Topic: Is this Vero Layout correct?  (Read 4412 times)
Muthauzem
« on: May 28, 2007, 04:19:12 PM »
I believe it is... But is always good to ask
PS:. (The darker part in the e-caps are the positive ones, At least in this picture =x)
Thank You
cab42
Re: Is this Vero Layout correct?
« Reply #1 on: May 29, 2007, 05:20:43 PM »
Looks good.
One thing: As far as I can see, the wire from pin 3 (the upper one) on the gain pot should go to row d instead of row f.
I guess that C3 is not soldered to row d?
Personally I would also credit Gus Smalley for the design.
Regards
Carsten
« Last Edit: May 29, 2007, 05:25:52 PM by cab42 »
Muthauzem
« Reply #2 on: May 30, 2007, 12:52:07 PM »
That's it... the C3 is not soldered to the row "d"... I just added the jumper to fit it there without moving it to the next column..
And the wire is really placed in the wrong spot.. I'll fix it later...
And about credits, I really didn't credit anybody because I assumed that everyone here knew that it was designed by Gus... but if it's better, I can put a credit to him on the picture =)
Muthauzem
« Reply #3 on: June 01, 2007, 12:06:25 PM »
Ok.. here it is with the corrections:
I'll try to build it soon... see what happens.
Bye
cab42
« Reply #4 on: June 04, 2007, 06:54:47 PM »
Looks good!
I will recommend that you use a socket for the transistor. This way you can try different types.
Have fun
Carsten
newfish
« Reply #5 on: July 11, 2007, 07:45:03 AM »
Built one of these little beasts late last night - using this stripboard layout.
Will post later with results as it was a little too late to play with amps.  ;D
Many thanks for posting the schmatics / layouts guys - and for the excellent help forum.
Cheers!
Happiness is a warm etchant bath.
andmej
« Reply #6 on: July 11, 2007, 10:40:41 AM »
Hello nice people. I'm an absolute newbie so this may sound stupid but...
what is a vero layout?
By the way, this is my first post and my first project as well so please don't be hard at me.
Nice forum!
Thanks.
If our brain were so simple that we could understand it, then we would be so stupid that we couldn't understand it.
aron
« Reply #7 on: July 11, 2007, 07:15:40 PM »
Vero and stripboard are the same here. It's a way of utilizing the built in tracks of copper on the board so you can "wire" a circuit without having to create a printed circuit board.
newfish
« Reply #8 on: July 12, 2007, 02:54:05 AM »
Yes! Yes! Yes!
Can definitely say this layout works - and it's amazing how much gain you can get out of such a small circuit.
Just need to box up and will soon have a new 'Pedal of Choice'.
Thanks to the techies and boffins for posting these diagrams.
 :icon_wink:
andmej
« Reply #9 on: July 12, 2007, 09:18:57 AM »
Very interesting. Where can I get one of those?
aron
« Reply #10 on: July 12, 2007, 06:58:56 PM »
In the STORE link above.
http://www.diystompboxes.com/cart/
