Author Topic: Removing the 5K pot?  (Read 3299 times)
theburge0318
« on: May 29, 2007, 12:23:01 AM »
If I were to remove the 5K pot would the pedal run at full blast all the time or would I need to sub in different values in the rest of the circuit to give it boost?
jonathan perez
Re: Removing the 5K pot?
« Reply #1 on: May 29, 2007, 12:38:06 AM »
if you want a resistance of 500k (in place of the pot wide open), then just use a 500k resistor in place.  :)
theburge0318
« Reply #2 on: May 29, 2007, 12:52:42 AM »
Ah!  ;D  So simple... thanks for the heads up.
I still need to integrate the 47uf cap (currently attached to the pot), would I not?
jonathan perez
« Reply #3 on: May 29, 2007, 01:00:45 AM »
sure, itll go in series/parallel with the resistor.  8)
