Author Topic: [wtb] beginner low noise power supply  (Read 3047 times)
teddybear
« on: June 16, 2007, 12:16:18 AM »
need schematic powersupply for beginner 9volt. (low noise)
thx
petemoore
Re: [wtb] beginner low noise power supply
« Reply #1 on: June 16, 2007, 12:57:31 AM »
  Hard to beat a VS 1 Spot adapter..
  Or.
  Use filter caps and wall wart
  Use wall wart with voltage regulator
  Building a PS involves working with high voltage, sealed plastic 1Spot is very stiff and steady DC output = low noise, powers lots of pedals daisy chained.
  If you're going to build it, consider 'the Spyder' [I recieved the transformer today, I'm trying to get a clue what the 20 wires emanating from the 4 corners are to be assigned to or where the primary and secondaries are or...anything...
  The spyder, when figured out will breaks ground loops by making all the outputs decoupled and completely independant.
  If I don't find what didn't come as promised IMO...the 'code' in 'color coded wires' purported to be with the Weber spyder transformer...I'll have to start at the drawing boards to figure out all that what's surley been figured out...hard to believe this thing didn't come with a diagram, chart, or wiring texts...what a whole lot of unnecessary work for each person new to it to have to go through...ughhh...and at safety levels of high voltage too !
  For every other transformer I've had, charts, texts, and diagrams were made available...but they had a fraction of the wires...
teddybear
« Reply #2 on: June 16, 2007, 01:14:23 PM »
in my country hard to find custom transformator.
i use 3A tranformator. could this thing do the job?
or maybe any diy i should try?
thx
newbie builder
« Reply #3 on: June 17, 2007, 11:27:57 PM »
Maybe you'd like to buy a kit- small bear has what you've described already detailed out.
http://www.smallbearelec.com/Categories.bok?category=Kits+And+Designs
mewithyou
« Reply #4 on: June 17, 2007, 11:54:21 PM »
dude what i did was i went to harbor freight and bought a adjustable wall ac-dc converter or $3.00 and riped off the plastic casing and put the transformer in my chassis ill have pics up in a little
teddybear
« Reply #5 on: June 27, 2007, 02:21:05 PM »
i wanna ask about spyder using single diode rectifier bridge or rectifier bridge?
thx
Violent5
« Reply #6 on: June 27, 2007, 04:51:10 PM »
I'm new to the forum.  I built a few pedals a few years ago and just finished a couple of new builds.  It seemed like time to get myself a power supply so I ordered small wart 200 kit from Small Bear.  It was an easy project and now it's something I use everyday.
teddybear
« Reply #7 on: June 28, 2007, 02:02:00 PM »
so 1 transformer = 1 output?
David
« Reply #8 on: July 02, 2007, 11:53:39 AM »
No, not at all.  You can have multiple outputs as long as they are wired in parallel.
nordine
« Reply #9 on: July 02, 2007, 12:40:54 PM »
Take the output of your transformer (assuming it gives more than 9 V), and put this snippet at the end of it:
(from: http://www.mitedu.freeserve.co.uk/Circuits/Power/9v2a.htm )
you can take out the diode, but not the regulator (7809)
being 2A, with that you can feed lots of pedals (take the power outputs in paralell)
widdly
  • Guest
« Reply #10 on: July 03, 2007, 03:30:33 AM »
Wouldn't you need a full-wave rectifier in there?
EDIT: Oh now I see it's for DC to DC. never mind
« Last Edit: July 03, 2007, 03:58:15 AM by widdly »
teddybear
« Reply #11 on: July 03, 2007, 09:28:24 AM »
so i see.
from the output vac, i could parallel the output.
thx
petemoore
« Reply #12 on: July 03, 2007, 09:32:54 AM »
  regulators like that generally need 2v to work with,
  that'd be at least 11v,
  >12vdc,  <35vdc for input would be good.
  power supply?..the Spyder is certainly worth taking a look at.
teddybear
« Reply #13 on: July 03, 2007, 09:38:11 AM »
i meant the output vac. (parallel).
