Author Topic: Does this kind of toggle exist?  (Read 1512 times)
msurdin
« on: July 02, 2007, 05:28:43 AM »
I am looking for a toggle switch that will work for switching between 3 effects. I think i will need something with 2 rows of 4.
Does anything like that exist?
Here is the thread for what i will be using it for
http://www.diystompboxes.com/smfforum/index.php?topic=58851.0
Matt
soulsonic
Re: Does this kind of toggle exist?
« Reply #1 on: July 02, 2007, 05:33:56 AM »
Check out my NEW DIY site - http://solgrind.wordpress.com
msurdin
« Reply #2 on: July 02, 2007, 06:05:30 AM »
do they have the top ones anywear but on on on
msurdin
« Reply #3 on: July 02, 2007, 06:45:29 PM »
Paul Perry (Frostwave)
« Reply #4 on: July 03, 2007, 06:49:15 AM »
If you are looking for a classy rotary solution (two poles three position) then you can cannabalize old hifi amps, the selector switches (tape - aux - phono) are always 2P (for stereo) plus, they are designed for low level audio.
msurdin
« Reply #5 on: July 03, 2007, 08:49:16 AM »
I thought that 3 way slide switch would work because it had 2 rows of 4 points. But the center was off so I didnt think it would work for selecting through 3 things
ambulancevoice
« Reply #6 on: July 03, 2007, 09:17:21 AM »
or a dp3t toggle thats on small bear looks good to me
it'll switch between the in/outof three effects
it will work fine
or you could use a 3p4t rotary can do the same, but with a multi coloured LED for indication of what effect is on, like on BYOC's tri boost use a 3p4t rotary to switch bettween three different boost effects with a multi coloured LED
« Reply #7 on: July 03, 2007, 09:51:23 AM »
The most space-conscious solution would be to use a slide switch.  Three position on-on-on switches can be easily purchase in footprints that are simply unattainable by either toggles or rotaries.  Obviously it's a damn sight easier to machine a hole for a rotary or toggle than a rectangular slot for a slide switch, but you'll appreciate the size thing in the end.
