help me please...how to put boost option on pt-80 delay?
Started by max77, July 06, 2007, 10:16:57 PM
max77
hi everybody , i need your help .
can i put boost option on pt-80 delay ? (for more volume)............. how to do ?
thank you very much
the boy from Thailand.
Brian Marshall
most likely you will have to edit the PCB, or build an extra PCB inside the enclosure. There are plenty of ways to boost a signal.
If you want to do it without adding parts, you can replace the 10K resistor feeding inverting input of the output opamp stage with a 10k pot(wired as a variable resistor), and perhaps a 2k resistor in series.
Unfortunately because of all the filtering in the circuit the output opamp tries to compensate for this, and boosting will alter this to an extent.
