Author Topic: Blendable Klon-type Overdrive  (Read 15270 times)
magikker
Re: Blendable Klon-type Overdrive
« Reply #80 on: July 18, 2007, 11:57:39 AM »
Ah ha....
I had guessed that the in betweens were the issue...
So, I guess we need it to be crisper clean on the clean side?
markm
« Reply #81 on: July 18, 2007, 11:58:32 AM »
The in-betweens are fine, the extremes are brutal!  :icon_lol:
magikker
« Reply #82 on: July 18, 2007, 12:24:31 PM »
it just struck me... at the extremes you are looking at a full gain distortion plus or a full gain micro amp right? I'm rarely a fan of any of my pedals at full gain... Were as at the extremes you probably want a 75% gain micro amp or 75% gain dist+ and none of the other effect?.... Is that right?
markm
« Reply #83 on: July 18, 2007, 12:42:23 PM »
Well, the D+ is a bit different than the 250 but, yes. I would say you are correct however, there will always be a bit of one on the other's full setting.
I myself don't go for Max Gain either, just a bit of break-up 'cause afterall, I play Country!
But, it gets unusable in either extreme where as the individual effects are usable by some at extreme settings.
The sound was, to use a better phrase, "not - pleasant" on the extremes.
A bit clearer would be the phrase, "it sounds like Crap!".  :icon_lol:
« Last Edit: July 18, 2007, 12:50:04 PM by markm »
freddd
  • Guest
« Reply #84 on: July 18, 2007, 12:54:25 PM »
When I built it on bread board I ended up lowering the gain available in both sections quite a bit, I just increased the resistors that head for ground after the gain pot. I can't remember the exact values I had - they still needed some tweaking anyway.
Ben N
  • Total likes: 420
  • Ben N. - really! Now Israel, once Baltimore
« Reply #85 on: July 18, 2007, 03:55:04 PM »
So this is meant to be an Old 97s pedal?  ;)
markm
« Reply #86 on: July 18, 2007, 10:08:18 PM »
Now that would not surprise me at all!
Bernardduur
« Reply #87 on: August 06, 2007, 10:54:32 AM »
I just finished this pedal, and it simply ROCKS!!!!!
The max settings are nice as you get a clean boost as a Distortion + like tone but the inbetween sounds are really killer as they tend to go from slight OD's to more distortion....... one problem is that the volume increases as I tend to go to the max settings..... in between the volume is quite lower then the extremes.
I run it now on 18V; they are just a microamp and a OD250. I simply placed an IC buffer stage / splitter before to get enough sound to both sections
Am learning something new every day here
SquareLight | MySpace account
markm
« Reply #88 on: August 06, 2007, 11:41:33 AM »
Did you build freddd's circuit?
So, you have a buffer on the input and that's all?
Bernardduur
« Reply #89 on: August 06, 2007, 11:55:10 AM »
Almost :)
I didn't use a buffer on the end but placed it to the start; the signal goes through two mix resistors to the 100k (log) volume pot
I also didn't add the trimpots yet; they'll come later I guess as I will replace the mix resistors with trimpots. I also added a cap over the 250 diodes.
Oh, and I kept the pedals individual 1/2V+ maker intact; I dunno if that is advised over one 1/2V+ maker for all positions.
I'll make a schematic of it
It sounds really really good!
« Last Edit: August 06, 2007, 11:58:38 AM by Bernardduur »
Bernardduur
« Reply #90 on: August 06, 2007, 12:36:59 PM »
markm
« Reply #91 on: August 06, 2007, 04:22:31 PM »
Schematic link
Thanks for that link Rogier, I'm going to have to try this thing out!  8)
Bernardduur
« Reply #92 on: August 06, 2007, 05:48:49 PM »
Yes;
I would love to have the volume a little bit more even but it is a GREAT pedal to play with!
freddd
  • Guest
« Reply #93 on: August 07, 2007, 06:31:55 AM »
Great stuff! It works... Interesting changes your made there. Are you gonna attempt to solve the volume issues?
Bernardduur
« Reply #94 on: August 07, 2007, 08:08:36 AM »
Yep; I am quite busy now (although my bass needs me first)
Noticed some mistakes in the schematic I will undo quite soon;
- The output cap on the microamp section is 15 uF, not 10 uF
- The volume pot is log; the program has no log pots
- Both gain potmeters are a double potmeter as described in the before section
« Last Edit: August 07, 2007, 08:10:56 AM by Bernardduur »
markm
« Reply #95 on: August 07, 2007, 08:14:40 AM »
Probably just an adjustment of the 10K mix resistors in the schem.
Although, would this not effect the highs a bit?
Bernardduur
« Reply #96 on: August 07, 2007, 01:16:40 PM »
Yes, it would I guess;
So therefor I go to mixing volume trimpots;
markm
« Reply #97 on: August 08, 2007, 03:07:11 PM »
So, what the consensus on the bias network?
Should it be shared amongst the two individual circuits -or- should each side have it's own since the values are different?
Bernardduur
« Reply #98 on: August 10, 2007, 06:38:03 AM »
No opinions I guess :)
When I connect all pedals to the same bias network the "sound" of the individual effects get less. So keep em in!
ppatchmods
« Reply #99 on: January 27, 2010, 05:08:52 PM »
did anyone ever get this thing working? the links are dead.
When your life is over, will any of this STUFF really matter?
