Hi Stephen,
It sounds quite good. Apparently you are adding the two delay line paths, which would give you flanging but not TZF. In order to have TZF you need to subtract the output from one delay line from the other (or equivalently, invert one and then add). This should give you the deep, mind blowing cancellation you are after.
