Author Topic: Weird Sounds, no effect  (Read 3472 times)
12milluz
« on: July 23, 2007, 10:12:34 PM »
I made the pedal, and all checks well as far as I can tell. But what happens is when I plug both cables in, I get nothing, then when I tap or jingle the circuitry, I get like a blast of sound, but no guitar sound. Sort of a hum. I'm not sure what I did wrong. Any help? :icon_cry:
Quote from: Processaurus
You need a glade plug-in, in on a footswitch.  Kick on the big muff, then hit the air freshener pedal.
Visit my site: http://www.freewebs.com/12milluzmusic
12milluz
Re: Weird Sounds, no effect
« Reply #1 on: July 24, 2007, 06:20:30 PM »
Nevermind, I fixed it. But, it seems that the pedal, while controling the volume, doesn't boost at all. IN fact, its loader without the pedal. Whats up with that? ???
12milluz
« Reply #2 on: July 24, 2007, 10:35:53 PM »
Since it wont let me modify, triple post :D. ANyways, hopefully SOMEONE will answer me on this. It is all working now, except it randomly blasts like pumps and booms even when i dont bump the pedal. I believe this is a grounding problem. Any advice?
CGDARK
« Reply #3 on: July 24, 2007, 10:55:01 PM »
Maybe is a bad solder connection. ??? Check every joint carefully and if they look dull resolder them until they get shiny (do not overheat the board).
CG
12milluz
« Reply #4 on: July 24, 2007, 11:09:44 PM »
its not on the board, i think its the solder joints on the switch now come to think of it. its gonna be a pain to redo AGAIN, but oh well
