Author Topic: Common Issue  (Read 6311 times)
12milluz
Common Issue
« on: August 05, 2007, 05:09:42 PM »
I have finally got around to finishing this pedal, and all the amplifiing works well. THe problem is, when the dial is not at full or nothing, it gives off a low level hum. I know this is a grounding issue. Also, when I hit the button, there is a pop. I know that is a grounding issue as well. My question is where are the places I need to ground from? I know there are no shorts.
Quote from: Processaurus
You need a glade plug-in, in on a footswitch.  Kick on the big muff, then hit the air freshener pedal.
Visit my site: http://www.freewebs.com/12milluzmusic
12milluz
Re: Common Issue
« Reply #1 on: August 06, 2007, 08:34:25 AM »
any ideas guys? I really wana get this finished
micro
Re: Common Issue
« Reply #2 on: August 06, 2007, 01:57:15 PM »
12milluz
Re: Common Issue
« Reply #3 on: August 06, 2007, 05:43:20 PM »
That is how I have it setup.
aron
Re: Common Issue
« Reply #4 on: August 06, 2007, 10:30:11 PM »
Measure your output (red probe) on output, black probe on ground and measure DC. I wonder if you have a leaky capacitor?
12milluz
Re: Common Issue
« Reply #5 on: August 06, 2007, 10:40:27 PM »
okay ill try that tomorrow in the morning, then ill update this
also, i hope youre referring to the capacitor attached to the pot... ::)
could heat damage cause that cap to preform like that?
« Last Edit: August 06, 2007, 10:43:35 PM by 12milluz »
12milluz
Re: Common Issue
« Reply #6 on: August 12, 2007, 02:04:25 PM »
Okay I did that, and I'm getting in the ranges or .4 to .75 DCV.
aron
Re: Common Issue
« Reply #7 on: August 13, 2007, 04:10:45 AM »
Are you measuring the junction of the 10uF output cap and the 100K resistor on the output? If so, yes, you shouldn't have that voltage there. I would suspect a defective capacitor or some other wiring problem.
12milluz
Re: Common Issue
« Reply #8 on: August 14, 2007, 12:07:35 AM »
oh no, i was using it at the 1/4" jacks. Ill do it again tomorrow
12milluz
Re: Common Issue
« Reply #9 on: August 20, 2007, 07:42:23 PM »
What is the popping caused by when I hit the switch?
GibsonGM
  • more
  • Total likes: 875
  • Mike Parker (aka. Guitar Mike, Parks, etc)
Re: Common Issue
« Reply #10 on: August 20, 2007, 07:46:21 PM »
Search for 'switch pop' in the forum, you'll find tons on this.  Basically, there is a potential difference between the thru signal and what's floating around at your input.  When you switch, the difference 'equalizes' itself, and manifests itself audibly as a "pop".  There are ways to minimize that.
Sometimes it also happens if there is an error in building the circuit (omitting the pulldown resistor, power where there shouldn't be, a missing ground connection, etc).
12milluz
Re: Common Issue
« Reply #11 on: September 27, 2007, 09:27:40 PM »
ok heres a new issue. havent used the pedal in a while, so i turned it on today, and now when i crank the pot to full, i get some country radio station coming through my amp lol
Barcode80
Re: Common Issue
« Reply #12 on: September 27, 2007, 09:29:21 PM »
grounding or shielding issue. are you using a metal case?
12milluz
Re: Common Issue
« Reply #13 on: September 27, 2007, 09:31:05 PM »
yes i am
and may i also state that it boost, but not cleanly. something else is still messed up im sure of. ill post a pic of my board later, although i dont think that is the issue.
