Author Topic: Echo Base - a new PT2399 delay  (Read 941181 times)
tasos
Re: Echo Base - a new PT2399 delay
« Reply #1060 on: June 04, 2011, 05:11:10 AM »
Yep!pee works great!
deafbutpicky
« Reply #1061 on: June 04, 2011, 06:54:54 AM »
Sorry for the link issues, somehow I can't edit my post so I'll try with this to fix the problem...
http://forum.musikding.de/cpg/displayimage.php?album=535&pos=0
http://forum.musikding.de/cpg/displayimage.php?album=535&pos=1
« Reply #1062 on: June 04, 2011, 11:31:57 AM »
The buffer looks fine.
The butchered version looks good, except that shape cw should be connected to pin 7 of U1. I don't think it will work connected after R28.
deafbutpicky
« Reply #1063 on: June 04, 2011, 04:56:37 PM »
As I took your vero for my own build and added the mods on this before I made my update vero, I tryied to stay as close to yours
as possible. This one slipped through. Actually the shape really acts a bit subtle, but I've got no comparison. Just in case,
here's another one. Had to add another line... darn :icon_wink:
http://forum.musikding.de/cpg/displayimage.php?album=535&pos=2
deafbutpicky
« Reply #1064 on: June 10, 2011, 06:41:15 AM »
During coffe break I took another look at my vero and guess what... found a mistake under U1.
 corrected version here:
mr_deadmaxxx
« Reply #1065 on: June 15, 2011, 05:32:33 AM »
done.
« Reply #1066 on: June 17, 2011, 11:57:26 AM »
@mr deadmaxxxx...
is that a 1590b?....if so which layout did you use?...i'd love to have a smaller echobase.....board space etc... ;)
mr_deadmaxxx
« Reply #1067 on: June 18, 2011, 12:29:28 AM »
layout from anonymousfacelesscoward.
poodlebra
« Reply #1068 on: June 18, 2011, 06:20:54 AM »
dimebugg pcb should slot in there easy too
Quality, cheap pedal parts, because the Poodle cares.
Germanium cans and diodes, PCBs, Full Stompbox Kits, UK's cheapest 3PDT:
http://www.pedalparts.co.uk/
« Reply #1069 on: June 18, 2011, 06:54:38 AM »
Taylor's PCB will fit fine as well.
Scruffie
« Reply #1070 on: June 18, 2011, 12:07:08 PM »
I think he said it'd only fit a 125B actually, which is a tiny bit bigger.
« Reply #1071 on: June 19, 2011, 09:49:18 AM »
yeah i thought that box looked a bit bigger than a 1590b!...hmmm...
egasimus
« Reply #1072 on: June 22, 2011, 08:15:33 AM »
I made a new layout for the Little Angel, incl. the dry/wet mod and the pin 6 potentiometer mod. Should theoretically fit into a 1590a, too. Will post it when I have time.
« Reply #1073 on: June 22, 2011, 08:37:06 AM »
cool... :icon_cool:
egasimus
« Reply #1074 on: June 22, 2011, 09:19:31 AM »
Damn, wrong topic :-[ :-X
~arph
« Reply #1075 on: June 22, 2011, 09:27:41 AM »
Would have been cool tho, an echo base in a 1590a  8)
« Reply #1076 on: June 22, 2011, 09:50:59 AM »
^now that i'd like to see... :icon_eek:
kipper_71
« Reply #1077 on: June 23, 2011, 05:46:41 PM »
Well, finally finished my build of this - certainly the most complex build I've ever attempted - and I was looking forward to a few evenings worth of debugging.
Plugged it in and ... it just works!  ;D
I've since spent the last hour with a fat ass grin on my face playing and playing.  This pedal is simply awesome.
Slacker - thanks, you are a true gent for sharing this.  The switchable delay time pots work a treat too - you do sometimes get a bit of strangeness for a second right after switching, but that just adds to the fun!
MarcoMike
« Reply #1078 on: July 02, 2011, 04:54:03 AM »
Hi, I am finally building one of these... but as I am not familiar at all with cmos switching I decided to go the hard-way....
and it seems all features of the original echo base are still unchanged, as the tails-option. and more, as in the configuration I am presenting, also a third mode is present, this is how I would describe them:
tails: no need to explain
direct: both "delay out" and "feed" are switched on at the same time. this way the delayed signal starts to generate when you switch the effect on
flashback mode: the feed of the delay is always on, so as you engage the pedal there is already something being delayed. and this is probably the same as in the original echo base.
so the 2nd mode is the new feature, no big deal. the great thing for me is no need for cmos switching!
* i didn't read the whole post, so all of this might already be known...
« Last Edit: July 02, 2011, 05:02:22 AM by MarcoMike »
Only those who attempt the absurd will achieve the impossible.
« Reply #1079 on: July 02, 2011, 08:09:27 AM »
Nice idea, you might need to add caps between the opamps and switch 1 though otherwise it might pop.
You could add the direct mode to the original design if you wanted to using a rotary switch for the tails switch and wiring it so one setting connected to both points A and B on the original schematic.
