Here's a pic of my by build made with Taylor's pcb. It sounds great. Thanks Slacker for the great design.[img]http://farm7.static.flickr.com/6132/6205445293_e3a235f7f4_m.jpg/img]
However, I built a second pedal on veroboard with the new buffer as seen on page 57 and I am still in the debugging process. Maybe someone can help me. I first made the mistake of inverting the polarity and also putting the bypass 2 wire on the 9 volts rail (witch at this time was actually ground because of my previous mistake). By then, I had a clean signal when bypassed but only ticking when engaged. After measuring voltages around PT2399 and CD4066, I noticed I had negative voltages. I corrected the wiring and changed both TL072(just in case). Now there is only ticking on both bypass and engaged mode. I measured the voltage again and it shows 0.6 volts across ground and +9 V. (The pedal is powered by via an adapter so that's not the problem).
Does anyone see an obvious component that maybe fried, like D1 or something I should try first.
Thanks everyone,
Marc
