Congrats on a great project.
Cheers
Hopefully you'll get yours debugged.
Thanks Ian! I just need a little switch for that short/long to make it work?
Yeah, when the switch is shut the 100R resistor is connected to ground giving the extra PT2399 has a very short delay which you won't hear when combined with the original one. When the switch is open the 100R and the XXX resistor are connected in series to ground so you get a delay from the extra PT2399 which is added to the original one to give the longer settings.
The long delay resistor, what would be the 'longest' clean value? Just to get an idea which values I should get for testing.
I'd try values between about 30k and 47k.
You also said something about other values I might need to change, can you clarify that a bit?
I'm not sure if anything will need changing but with 2 chips there will be a bit more noise than with one so you might need to change some of the capacitors to filter it out. At a guess the 4n7, 15n or 470p capacitors might need increasing in size, so maybe get some extra 1n, 10n and 22n caps to experiment with.
Like I said this mod works in theory but I haven't actually built it so we might have to figure it out as we go
