Author Topic: Echo Base - a new PT2399 delay  (Read 940206 times)
Re: Echo Base - a new PT2399 delay
« Reply #200 on: July 24, 2008, 05:47:16 AM »
I think it will work and it doesn't matter which way round you put it. I think it's probably better to replace it with a non polarised cap though if you can.
Valoosj
« Reply #201 on: July 28, 2008, 05:07:11 PM »
Sweet, changing the 2 47Ks to 20K worked. When I hit a chord in bypass, and immediatly mute it you still hear a faint repeat. This is probably normal as the pedal isn't true bypass. Other than that, this is a really cool delay. Definetly a keeper. Thank you slacker!
as for the extra delay time, if anybody asks for it I can post the adapted layouts and stuff. The repeat gets some OD, but that doens't bother me at all.
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
evilpaul
« Reply #202 on: July 28, 2008, 07:34:21 PM »
I'm interested in the adapted layouts, post 'em up!
Tuemmueh
« Reply #203 on: August 03, 2008, 05:49:51 PM »
+1
Valoosj
« Reply #204 on: August 06, 2008, 05:18:15 PM »
Sorry for the delay  ;D (pun very much so intended)
Now I just have one question for you. I want to use an LDR to add more feedback since I love the oscillation. How should I wire it? Hook up one leg to lug 1 and the other to lug 3 of the feedback pot? I want it to increase in feedback as I dim the light on the LDR.
DWBH
« Reply #205 on: August 06, 2008, 06:58:55 PM »
Is the schematic on the first page 100% correct?
Boogdish
« Reply #206 on: August 07, 2008, 10:02:48 AM »
I was able to successfully build one using the schematic on the first page.  Just the feedback resistor needs to be selected for your personal taste.
« Reply #207 on: August 07, 2008, 01:08:43 PM »
Yes, it's correct. The version in my layout gallery had a few pin numbering errors on the 2 opamps but I've corrected that now as well.
« Last Edit: August 07, 2008, 01:17:47 PM by slacker »
Valoosj
« Reply #208 on: August 07, 2008, 03:42:29 PM »
Use the verified layout in the pdf file. I used that pcb to add the extra time mod.
Nobody knows how to do the thing I asked in my previous post?
ppatchmods
« Reply #209 on: August 08, 2008, 12:30:38 PM »
Is there a wiring diagram for the jacks and switches?  I'm kinda new to reading the layouts.  Also, is their a replacement for the 7805 transistor?  Small bear doesn't carry them. Thanks
-John
When your life is over, will any of this STUFF really matter?
« Reply #210 on: August 08, 2008, 12:48:45 PM »
My vero layout show the wiring for the jacks and switches, it's the same which ever layout you use.
http://www.aronnelson.com/gallery/main.php/v/slackers-stuff/echobasefinal.jpg.html
The 78L05 that smallbear carries should be fine, I think other people have used them.
http://www.smallbearelec.com/Categories.bok?category=ICs+-+Voltage++Regulators+and+Converters
ppatchmods
« Reply #211 on: August 08, 2008, 12:57:19 PM »
Thanks Slacker!
Valoosj
« Reply #212 on: August 08, 2008, 04:55:56 PM »
Since no one feels like answering my question I'll come up with the solution. Slacker, could you verify this?
If I add and LDR on LUG 2 and 3 (left and middle with the shaft down and the lugs facing me) would that increase the feedback when I dampen the incoming light on the LDR?
I haven't been able to test it, but I think this should do it.
Here's a pic of my finished Echo Base fields.
Filament
« Reply #213 on: August 08, 2008, 05:25:10 PM »
Regarding verified layouts, I can attest that the latest anonymousfacelesscoward layout is good.  Some may like it as it's a good bit smaller than his original one.  I was able to squeeze it into a 1590.  I won't post it since it's not mine but you can find it on his site.
This is not my large automobile
Gila_Crisis
« Reply #214 on: August 11, 2008, 05:01:56 PM »
i built it and i'm really pleased, it sounds really really good!!!
btw what value do you suggest for R17? on mine i used the standard 20k resistor, but it's too low, already before 3/4 of the feedback pot it start selfoscillating!!! :icon_eek:
Barcode80
« Reply #215 on: August 11, 2008, 08:43:40 PM »
what type of switch? i know you only need single throw, but is it momentary like boss that is required or is latching required?
« Reply #216 on: August 12, 2008, 07:30:51 AM »
For the bypass footswitch you need a SPST latching or use a half a SPDT latching as they are probably easier to get hold of.
ppatchmods
« Reply #217 on: August 12, 2008, 11:53:57 AM »
Is the toggle switch a on(on) w/ 3 lugs?  I thinks that's right, but just checking before i pick one up. Also, on the newer layout, do all the ic's face the same way? thanks
« Reply #218 on: August 12, 2008, 12:02:34 PM »
Yeah the tails/Boss toggle is a SPDT on/on latching switch.
Not sure about the layout, you mean the compact anonymousfaceless one?
ppatchmods
« Reply #219 on: August 12, 2008, 12:26:19 PM »
yes, the anonymousfaceless one.  It appears they all face the same way, but I think I read that someone fried an ic assuming the same thing. Thanks Slacker!
