Hello everybody!!
Finally I was admitted to the forum...
I read and studied all the 16 pages of the thread..
So 2 weeks ago I decided to build the echo bases because I like a lot the idea of tail circuit.
After lots of problems the fx now works well...
I post my build report, maybe some information
I would be happy if I could help someone that have problem to start echo on it's own fx.
19.11.2008 Italy
At the first the fx didn't work at all.
The only sound emitted was a bzzzzzzzzzzzzzzz like a "wonderful" short somewhere in the circuit. AARRRGGHH!
After triple check of components and a night past over the pcb I found no errors in connections.
I was sure that the pt2399 was working well as i used to hear behind the bzzzz the echo.
I also tried to change one operational (4558) with other 2 similar.
At the end I discovered that the problem was due to the lfo operational..
I discovered also that the 2 others 4558 that I tried to change was shorted
I was so mad... I was getting literal crazy.
3 operational broken from the start... never happened before... (Hope nevermore)
After replacing the lfo op the sound It's ok.
It has a good sound..
The repeats become a little "harsh" as you increase the speed pot (after 500ms). but It's ok, it's like my others reb2.5.
I like a lot the tail switch tail... It is a wonderful idea (useful to me)
(feedback pot too big, I'll replace with another one like 25k)
The LFO modulation is a strange point. After a while I found a good setting.
I see that the depth pot affect the speed of the repeats of the pt2399.
Maybe as I use a bigger pot than the one in the scheme could it be the cause?! Infact at that position the depth is too deep... and become a strange funny fx that bends the notes played.
Now I'm happy of my new delay. So now I 've 4 delays in my fx chain: rebo1e 2.5 - rebo2e 2.5 - the danelectro reel echo.... and the echo base that I will call "The last Echo" (I like p.floyd sound so now I can become crazy with all those delays
Another good fx after my other builts: Rat, Small clone chorus, 2 ts808, phase90 and tube amp P1-ex.
Bye and thanks at all, I'll be around this forum for long time.
Paolo R
