Thanks Slacker I can't wait to build this... and would love to see a butchered layout...
The first thing you need to sort out is why the 2N5089 isn't working, if the the collector stays low then the effect is always bypassed, that's why you can't hear any delay. Make sure the transistor is the correct way round, on my vero layout the collector is at the bottom. After that check for shorts or wrongly placed components or component values.Same things apply to your funny pin 4 voltage on the LFO opamp, it looks like it's shorted to one of the other pins, also check the value of the 220R resistor to make sure it's correct and that it's connected to ground. Hopefully once that's fixed the LFO will work.Hope that helps
Quote from: championdjk on February 21, 2009, 12:32:18 PMThanks Slacker I can't wait to build this... and would love to see a butchered layout... Here you are http://www.aronnelson.com/gallery/main.php/v/slackers-stuff/album170/echobasebutchered.jpg.html?g2_imageViewsIndex=1I couldn't be bothered corrected the component numbering, but it should be easy enough to figure out.
I'll crack mine open and measure the PCB for you tonight.
Anybody ever try running one delay circuit through another like that? Is there anything I need to watch out for?
Quote from: andrew_k on March 03, 2009, 05:28:36 PMI'll crack mine open and measure the PCB for you tonight.That'd be great! Cheers!
