I just made a second Echo Base. For this one, I decided to use a 1Meg linear pot for the delay time.
Haven't timed it yet, but at maximum I'd say this gives you around 10 second long delays. Of course, there is a fair amount of noise and distortion/bit crushing going on at this setting, but for my purposes it's quite fun. I stuck a lowpass filter after it. It's a bit more lo-fi than the Lo-Fi Loop Junky, and not as much time, but it has one excellent feature that no other lofi looper has - overdubs.
It sounds the same as my other one at short delay settings.
Unsurprisingly, high notes are useless here because you have to filter them out to filter out the noise, but for you guitar guys, the low end of the neck is reproduced reasonably well. The lowest octave of my bass doesn't come through so well at these long times; I think the low notes are creating too much distortion to be heard clearly.
So, overall, a very fun mod. If you're into weird stuff, give it a shot. It kind of makes the Echo Base into a whole new pedal - it was already an analog-ish digital delay, chorus, and vibrato, but now it's a lofi looper.
And now a question: I find the Mod depth and speed knobs to be hard to pin down. It seems that there's only a narrow area where the knobs do anything, which shifts around depending on other settings, and once you hit that area, you're immediately in Skronkville. Does anybody else find this to be the case? Any thoughts on how to make the Mod section a little more predictable?
Also, since people are using it to do chorus and vibrato, it might be nice to turn the delay volume control into a mix control, so you can have just the vibrato without the clean if you want. I don't have time right now to draw this up, but I think it would be more useful than the way it's currently set up.
EDIT: Don't try this yet! May be bad. See below.
