Author Topic: Echo Base - a new PT2399 delay  (Read 939977 times)
gefi
Re: Echo Base - a new PT2399 delay
« Reply #900 on: October 05, 2010, 10:12:15 AM »
Hello
my english is not good and after reading the 45 pages I'm a little confused
This PCB is correct?
http://blogs.yahoo.co.jp/anonymousfacelesscoward/19192939.html
thanks
« Reply #901 on: October 05, 2010, 03:04:46 PM »
Hi
Yes that PCB is correct.
Galego
« Reply #902 on: October 07, 2010, 03:19:23 PM »
http://www.youtube.com/watch?v=EAp9nKNCuQs
This is not an echo base anymore, but it was based on it, using the PWM output of a PIC 16F684 instead of the LFO. Please let me know what you think, or any suggestions on how to improve it's functionality.
Brief explanation:
Left Led (red) - tempo indicator.
Red and Green led - binary sequence that shows the current mode selection:
 00 - Tempo and Load preset 1
 01 - multiplier and Load preset 2
 10 - mod speed and Save preset 1
 11 - mod depth and Save preset 2
One button is for tap tempo, the second cycles through the 4 modes, and the third saves or loads a preset depending on which mode is selected.
The values are changed with a rotary encoder. The other two knobs are for the delay feedback and level.
When the unit is turned on, it loads preset 1.
« Reply #903 on: October 07, 2010, 04:14:31 PM »
Looks interesting, nice work :)
candletears7
« Reply #904 on: November 17, 2010, 06:12:15 PM »
I just built mine up from Taylors PCB.
A big thank you to all involved, Slacker, Taylor. This is a great delay/modulation effect. Mine fired up first go, except for the fact that I had wired all pots in reverse, but 10 minutes later it was doing what it should. An excellent pedal! Cheers again!
« Reply #905 on: November 18, 2010, 01:13:39 PM »
Cheers :)
phector2004
« Reply #906 on: November 18, 2010, 05:29:44 PM »
Just out of curiosity, I can use a 1N5819 schottky as a protection diode, right?
or will bad things happen to me if I put in an opposite-polarity jack?  :icon_evil:
« Reply #907 on: November 18, 2010, 05:34:47 PM »
Should be fine. Probably even better than a silicon, because of the lower forward drop of a Schottky.
phector2004
« Reply #908 on: November 18, 2010, 05:39:10 PM »
Nice. I can finally populate it
azrael
« Reply #909 on: December 02, 2010, 07:49:32 PM »
Hey, just getting onto the Echo Base boat here. I was reading through some of the older pages, but some links are broken. Anyone have the diagram for an effects loop on the Echo Base?
Also, is a dual PT2399 mod here possible? What about Tap Tempo? I understand the PTAP isn't being used any more, unfortunately...
Barcode80
« Reply #910 on: December 02, 2010, 08:00:22 PM »
I'm not sure about the PT2399 double up but I think it was mentioned in this thread that it is possible. ALso, there is a kit Aron sells (STORE link at the top of the forum page) called Taptation which is a tap tempo add-on for PT2399 circuits.
azrael
« Reply #911 on: December 02, 2010, 08:20:08 PM »
I remember looking there before I bought a PCB from Taylor, and not seeing any.
Double checked just now, I don't see them in stock anymore. :(
« Reply #912 on: December 03, 2010, 06:33:21 AM »
There's a double time mod that me and Valoosj did, the discussion about it starts on page 8 of this thread, there's a schematic and a layout.
For info about fx loops have a look at my post here http://www.electro-music.com/forum/viewtopic.php?t=39579&postorder=asc&start=375
Barcode80
« Reply #913 on: December 03, 2010, 11:51:55 AM »
Yeah, for some reason it's not on there anymore. Odd.
azrael
« Reply #914 on: December 03, 2010, 01:17:52 PM »
Awesome, thanks slacker!
If only I could get tap tempo now haha...maybe someone has an extra board...
Berger
« Reply #915 on: December 05, 2010, 02:10:00 PM »
ran into a weird one today. I have an echobase build from taylor's pcb. I found out with the echobase off if I put my amp into standby mode and strum the guitar quick.
When I put the amp out of standby mode, the echobase generates white noise.
Until I unplug its power and plug it back in.
I'm guessing the issue is with the buffer...any one else run into this?
Aaron
matej_mlody
« Reply #916 on: December 22, 2010, 11:20:23 AM »
I would like download PCB from http://blogs.yahoo.co.jp/anonymousfacelesscoward/19192939.html but I can't save this PCB to ORYGINAL Size. How to download this pcb in PDF file ? ofcourse to oryginal and appropriate size for all elements. If someone give me this PDF I will be really grateful! Greetings
Barcode80
« Reply #917 on: December 22, 2010, 12:36:09 PM »
Those files don't come out of DIY layout creator with the correct sizing. Resize the layout to 200.25 dpi and it will print marvelously.
« Reply #918 on: December 22, 2010, 12:40:30 PM »
this brings me to the question...
why do we always have to resize?....surely this breaks up/squares/pixelates the image, ???
or is it down to the author...hmmmmm.....you would think it was ready to print on a pdf eh?.. ::)
Barcode80
« Reply #919 on: December 22, 2010, 02:37:19 PM »
1) it's a lot easier to code an export to gif than pdf.
2) when you resize to a smaller image, there is no pixelation. that's only going to happen when enlarging.
I personally use bullzip pdf printer to print a lot of my layout work straight to pdf from express, but that's a lot to expect of someone providing free layouts...
perhaps you are looking the gift horse in the mouth a bit?   :icon_smile:
