Author Topic: tetrode mosfets?  (Read 3740 times)
$uperpuma
tetrode mosfets?
« on: September 21, 2007, 06:40:19 PM »
in the large lot of parts I got I got a ton of these... when I look up the parts numbers I don't find any data sheets, or internal diagrams... useful at all?
soulsonic
Re: tetrode mosfets?
« Reply #1 on: September 22, 2007, 01:36:35 AM »
Please excuse my ignorance, but what is a Tetrode MOSFET? Is it one of those ones that doesn't have the body diode internally connected so it has four leads?
km-r
« Reply #2 on: September 22, 2007, 01:44:30 AM »
must be a dual gate mosfet??
Look at it this way- everyone rags on air guitar here because everyone can play guitar.  If we were on a lawn mower forum, air guitar would be okay and they would ridicule air mowing.
« Reply #3 on: September 22, 2007, 10:14:56 AM »
http://www.ortodoxism.ro/datasheets/infineon/1-bf1009s.pdf
  http://www.datasheetcatalog.com/datasheets_pdf/B/F/1/0/BF1009S.shtml
  For low noise, high gain controlled
input stages up to 1GHz
 Operating voltage 9V
 Integrated bias network
  Looks to me like a VHF amp...
« Last Edit: September 22, 2007, 10:16:29 AM by petemoore »
$uperpuma
« Reply #4 on: September 22, 2007, 11:01:21 AM »
thanks for the info guys... should probably be MY ignorance that should be excused.... just trying to ID the parts I've got...  keep and use the ones I can, and pass the rest on to someone who will use them.
thanks!
Sir H C
« Reply #5 on: September 22, 2007, 05:24:58 PM »
Could these be used in the tremolo from Walco?  I would guess you could run them as a cascode device pretty easily.
markm
« Reply #6 on: September 22, 2007, 05:35:23 PM »
Nate, these aren't SMD are they?
$uperpuma
« Reply #7 on: September 26, 2007, 10:38:52 PM »
Mark, nope, standard metal can package, but four legs.. which from has been said here, is probably 2 gates...
