Author Topic: the building of my insane pedalboard  (Read 19242 times)
kurtlives
Re: my setup, with questions
« Reply #40 on: January 06, 2008, 05:20:53 PM »
Can it boost your signal?
Looks good!
Valoosj
« Reply #41 on: January 06, 2008, 05:42:08 PM »
It goes from complete silence to a little boost.
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
snoof
« Reply #42 on: January 07, 2008, 10:57:44 AM »
Which circuit are you using for the active vol pedal??  I'm looking for one myself.
Valoosj
« Reply #43 on: January 07, 2008, 03:37:41 PM »
This is where I found the schem.
http://www.tonepad.com/project.asp?id=12
Todays work: Tremulus Lune and ROG Thor
snoof
« Reply #44 on: January 07, 2008, 03:39:21 PM »
thanks.  I saw that one a while back, but that damn 3080 is a PITA. :icon_evil:
Valoosj
« Reply #45 on: January 07, 2008, 03:50:56 PM »
PITA?
snoof
« Reply #46 on: January 07, 2008, 03:59:41 PM »
Pain In The Ass.... 8)  Hard to find for a decent price.
« Last Edit: January 07, 2008, 04:01:52 PM by snoof »
Valoosj
« Reply #47 on: January 07, 2008, 04:06:58 PM »
mine was 2,2 euro
kurtlives
« Reply #48 on: January 07, 2008, 06:31:22 PM »
Why do you like the box stlye caps?
Valoosj
« Reply #49 on: January 07, 2008, 06:34:35 PM »
I have no preferences, I just buy the stuff I can get here. What other kind would you use? SMD perhaps?
kurtlives
« Reply #50 on: January 07, 2008, 08:27:40 PM »
Nah...just poly film.
Valoosj
« Reply #51 on: January 08, 2008, 05:56:46 AM »
Does that actually make a difference?
Valoosj
« Reply #52 on: January 08, 2008, 05:19:58 PM »
Real tube screamer, 4x SHO, Ross Phaser, Payback and RoG MayQueen.
kurtlives
« Reply #53 on: January 08, 2008, 06:46:17 PM »
Somebody has got better at making boards ;)
Valoosj
« Reply #54 on: January 08, 2008, 06:55:33 PM »
I have made huge progress since I started a year ago :)
However, I did forget 3 board : Neovibe, Big Muff and another box of rock. Those are for after my exams. I really should study :D
Valoosj
« Reply #55 on: January 09, 2008, 02:43:32 PM »
And I finished the onboard wiring for the MayQueen.
Progress report:
Finished!
Volumepedal
AB/with buffer
Troubleshooting
On board ready
SHO
Boutique Box of Rock
Tremulus lune
Thor
MayQueen
Drilled
Etched
Real Tube Screamer
Payback
Ross Phaser
2nd SHO
To print and iron
Neovibe
2nd BoR
Big Muff
On Auke Haarsma's drawing board
Delay
Valoosj
« Reply #56 on: January 23, 2008, 09:31:43 AM »
Latest work: making a layout for the Payback.
I'm currently working on the layout of a tube overdrive. Once that's finished I can start etching again.
Valoosj
« Reply #57 on: January 23, 2008, 05:35:57 PM »
Latest work : Real Tube Screamer, big muff, payback, BoR and mil bypass.
Valoosj
« Reply #58 on: January 26, 2008, 09:43:06 AM »
I finally got back to work!
Box of Rock that I'm building for a friend. Not finished because I'm missing 1 pot. It worked fine without debugging.
Tremulus Lune, which will feature plexiglass at the bottom like Arph did.
I redid my own SHO, and put diffused leds in my A/B. Currently I'm trying to finish my Trem Lune.
Progress report:
Finished!
Volumepedal
AB/with buffer
Layout and drilling the box
Troubleshooting
On board ready
SHO
Tremulus lune
Thor
MayQueen
Drilled
Etched
Real Tube Screamer
Payback
Ross Phaser
2nd SHO
To print and iron
Neovibe
Delay
[/quote]
« Last Edit: January 26, 2008, 09:46:06 AM by Valoosj »
Valoosj
Re: the building of my insane pedalboard
« Reply #59 on: January 28, 2008, 06:53:36 PM »
The Tremulus Lune is nearly finished. I had some minor debugging with it.
Gutshots!
Still have to drill the knobs (they only fit 6mm pots, mine are 6,3mm)
And then I need to find some plexiglass...
