small question about coupling caps
Started by dschwartz, December 04, 2007, 08:50:52 AM
dschwartz
Hi there...
i have a small question about frequencies affected by a coupling cap on tube preamps...
i assume that the resulting filter is a product between the previous triode output impedance, next triode input impedance and the cap itself..
is there any way i can calculate the corner freq?
Tubes are overrated!!
http://www.simplifieramp.com
GibsonGM
I'd assume using the standard formula F=1/2pi*R*C works  ..... but you would have to have the other information.  Maybe you can get close from tube data sheets or running a simulation with software?  I don't think the Miller Effect would have much to do with anything, as it is very small, but the impedances would for sure, as you've stated.
I approach this by either using known values, or 'plug and play' to see how cap changes are affecting stages.
Good question.
Gus
alfafalfa
Daniel,
I use a small Exel file in which I can change the values of cap and resistors to get the right cutoff frequency.
If you pm me with your address , I'll send it to you.
Alf.
dschwartz
thanks!!that spreadsheet and aiken amps articles are simply wonderfull..
