Author Topic: Tube boost + overdrive running off a 9 volt battery  (Read 1732981 times)
dano12
« on: December 11, 2007, 07:51:24 PM »
Matsumin's Valve Caster, a 12AU7-based booster and light overdrive running at 9 volts. A very fun little circuit that has a minimal parts count and actually generates a good amount of boost and some overdrive.
It appears Matsumin's site has gone 404'd on us, but here is my redrawn schematic with a few cap substitutions.
You can even run this one of a 9 volt battery if you don't mind chewing through batteries :) Otherwise, and 9 volt adaptor will be fine.
I was particularly surprised as to the effectiveness of the simple tone control...
Enjoy!
<edit: also simple enough to build 90% of the circuit right on the back of a tube socket>
« Last Edit: December 11, 2007, 08:32:16 PM by dano12 »
Marcos - Munky
Re: Tube boost + overdrive running off a 9 volt battery
« Reply #1 on: December 11, 2007, 09:16:12 PM »
Cool!!! Any soundclips? I have only one tube, and don't know what to built with it, so I ask for soundclips to know how it sounds.
kurtlives
« Reply #2 on: December 11, 2007, 09:31:18 PM »
Nice
Anymore pics of the whole circut?
Zben3129
« Reply #3 on: December 11, 2007, 11:04:42 PM »
Not that familiar with tubes....
but 12au7....can this be a 12ax7 in this case?
Zben3129
« Reply #4 on: December 11, 2007, 11:19:42 PM »
After a little more research, it seems that au and ax are correct pin for pin, and the ax has about 7x more gain than au. However, i dont know if it is possible to run the ax in this circuit due to 9vdc?
Also how will the sound be? If its more overdriven, that could be a good thing. I'm just looking to get into tubes a little
MasaRGR
« Reply #5 on: December 11, 2007, 11:37:09 PM »
He moved his site recently to a new address http://www.matsumin.net/
Thanks for the schematic! Looks like fun :)
Papa_lazerous
« Reply #6 on: December 12, 2007, 12:43:28 AM »
this is getting built this weekend!  got all the bits sitting around.  Nice bit of tube mojo to add to the pedal board I think  :D
jakenold
  • Guest
« Reply #7 on: December 12, 2007, 03:02:07 AM »
Nice work dano!
I was wondering, what needs to be changed say I want to run this at high voltage?
dano12
« Reply #8 on: December 12, 2007, 09:22:41 AM »
No clips yet, but it sounds pretty nice. On the overdrive side it is a bit raspy, but I think that could be tamed with some filtering caps.
Will try and box it up tonight for pix!
If I remember correctly, the relative gain of the 12A*7 tubes goes something like this:
12AU7   20
12AV7   40
12AY7   50
12AT7   60
12AX7   100
I built it wih the 12AU7/12U7 as specified on the schematic. I tried a 12AT7 and it was too much gain and sounded really bad. I also tried a couple of 12AX7s and it sounded even worse--pretty much unusable. I'm not really very knowledgeable about biasing tubes, but I suspect using an AT7 or AX7 will require resistor value changes.
From the little I know, you'll probably want to go up to 12vDC to use the AX7. Here's a diagram for using a 12AX7 as a clipper pair based on info from another thread here:
So 12 volt to heater 4 and heater 5 to ground might work.
Thanks very much for the link! I'll update my schemo tonight to add the new URL.
Nice work dano! I was wondering, what needs to be changed say I want to run this at high voltage?
I think this design made the usual compromises to run at low voltage. If you are going to create a tube boost/overdrive and are using high voltage, that are lots of better designs out there.
Thanks to Matsumin for this fun circuit.
kurtlives
« Reply #9 on: December 12, 2007, 05:56:33 PM »
Could you post a vero layout?
Does the tube light up btw?
Papa_lazerous
« Reply #10 on: December 12, 2007, 08:03:21 PM »
The tube will have to light up or it wouldn't conduct....
You could do as the picture above and put most components on the tube socket, or even a nice little tag board layout.  Its really such a simple build it might be a good learning excersize to try and make your own layout and then post it here and ask someone to check it over.  Should only take a short time  ;)
Zben3129
« Reply #11 on: December 12, 2007, 08:08:43 PM »
I may try this out. Does anyone have a spare 12au7 or socket?
dano12
« Reply #12 on: December 12, 2007, 08:53:35 PM »
Vero is left as the dreaded "exercise for the reader". Mainly because I suck at vero. But you can build it entirely on the tube socket, pots and jacks.
And yes, it does glow!
kurtlives
« Reply #13 on: December 12, 2007, 09:02:53 PM »
Alright thanks, that is probbly what I will do.
I am new to building frm schems.....Is this negative ground?
How do I wire the 3PDT? WHere is the input and output?
the_random_hero
  • Great Contributor!
  • Total likes: 0
  • Electrical Engineering Student - Call me Drew
« Reply #14 on: December 12, 2007, 09:07:04 PM »
Looks awesome, but have you tried running it on 12VDC? I'm sure you would get a lot nicer response out of it :)
Completed Projects - Modded DS1, The Stiffy, Toaster Ruby, Octobooster Mk. II, Pedal Power Supply
Aren
« Reply #15 on: December 12, 2007, 09:20:50 PM »
I was just wondering the same thing...
Also, it seems like it could be a fantastic input stage in front of a 386 based practice amp or a speaker simulator. I'll try to get my hands on a 12AU7 and build one of those. Does it require an 8 pin socket? (sorry, completely clueless about tubes...)
Can anyone recommend a good supplier that will ship to Canada?
kurtlives
« Reply #16 on: December 12, 2007, 10:45:39 PM »
^tubesandmore.com
12AU7   20
12AV7   40
12AY7   50
12AT7   60
12AX7   100
If I wanted to use something besides a 12AU7 would I need to do any mods?
dano12
« Reply #17 on: December 13, 2007, 09:31:09 AM »
Regarding the 386 amp, that's the route I'm taking with my wired tube socket thing. Trying to fit it in a small plastic case.
For the questions about using a tube other than the 12AU7, as said earlier, they are higher gain and won't work nicely unless you modify the circuit, I don't know how to do that part.
tubesandmore.com has the tube and sockets, it is the standard 9-pin tube socket you would use for guitar amp preamp sections.
Here is a rough *unverified* wiring diagram for anyone who wants to try it.
GibsonGM
  • more
  • Total likes: 853
  • Mike Parker (aka. Guitar Mike, Parks, etc)
« Reply #18 on: December 13, 2007, 09:47:24 AM »
There are a few other circuits like this...the MarshaValve is one which feeds a JFET, I believe.  They're good ones to get started with tube work :o)
I think if you tried to modify the circuit for 12AX7 use, you might end up in a no-win situation....they're really supposed to run on 100+volts, and at 9v, that's just asking a lot!  But it's worth a try if you have something sitting on the breadboard.   There are also low-voltage tubes that would work nicely for a higher-gain setting.
Expect to blow thru batteries (use wall wart), the heaters draw a LOT of current!
letsgocoyote
« Reply #19 on: December 13, 2007, 02:35:02 PM »
after building 32154 different electra and bazz fuss variations, i think this may end up being the first new kind of project to tackle!
