Tube boost + overdrive running off a 9 volt battery
Started by dano12, December 11, 2007, 07:51:24 PM
Renegadrian
Quote from: Berger on April 29, 2008, 06:01:20 PM
Yup Dano this thread has taken off, its got me going crazy buying tubes, even better is that I'm starting to understand this stuff, and am having a lot of fun.
The only thin I notices is suppling enough amperage to the circuit for it to work right. I was using a 12volt 300ma radio shack wallwart and would get flubby sounds out of it. I switched to a 700ma power supply for work and it sounds amazing.
http://www.nj7p.org/Tube4.php?tube=6111
Heater Current ................................ 0.3 A
According to this, you need 600mA only for the heaters, am I right???
Dano, this thread is killer...Apart form the the first ones, like me,  Andrew and Kristian (krinor) I read more and more people interested in the Valvy...And the little effort in the building gives great satisfaction...You go like "WOW, i went TUBES!!!"  8)
Quote from: Renegadrian on April 29, 2008, 06:53:31 PM
Hmmm Renegadrian - maybe you just solved my Subcaster problem - not enough mA! I guess the 317 must consume some mA too - I will try a more powerful power supply.
Renegadrian
Quote from: frequencycentral on April 29, 2008, 06:57:18 PM
Rick, if that's the case, glad I gave you a hint!!!  :icon_wink:
Berger
Also a tip I ran a 220k resistor from the vin to pin 7 and that made a huge difference on my build as well
Jimmy-H
Hi there,
You don't neet the 317 with two tubes.
Just set the heaters of the two tubes in series, the current then is stil 0.3 A.
Right?
iorr
Hi Jimmy-H,
You need the LM317 of an IC 7812 to get a stable voltage on the heaters. Otherwhise you will shorten life of the tube(s).
I builded my Valvecaster with a wall wart 15V. and an IC7812, 100yF across the DC jack, pos.tip to pin 1 of the 7812, pin 2 to ground and pin 3 to the circuit.
Build the regulator on a heatsink.oh and connect only heater pins 4 and 5 of the tube.
Karsten
Jimmy-H
#466
Quote from: iorr on April 30, 2008, 04:26:14 AM
Hi Jimmy-H,
You need the LM317 of an IC 7812 to get a stable voltage on the heaters. Otherwise you will shorten life of the tube(s).
I builded my Valvecaster with a wall wart 15V. and an IC7812, 100uF across the DC jack, pos.tip to pin 1 of the 7812, pin 2 to ground and pin 3 to the circuit.
Karsten
Yeah, your right about that ;)
But if u use good regulated powersupply in the first place, than you don't have to worry about that.
The only thing you have to do is remove the 47 E resistor in the supply filter of the subcaster.
Because of the low Resistance of the heaters.
Otherwise your voltage will drop
With tubes it's always important to have a good power supply to prevent hum.
I experienced that with the pepper shredder
iorr
yep, regulated power supply is very importent.
Builded this for my audio preamp - a little bit oversized - hahahahah
Karsten
Woodooman
Hello there
Sorry for a newbish question, but could anyone please tell me if i could use 6n1p russian 6v tubes for this project?
thanks
Renegadrian
A quick glance at its details, and I believe this wouldn't be the best choice...
1) it runs on 6v, while the main tubes used here are 12v
2) it needs 600mA on heater
Fender56
#470
Quote from: Woodooman on April 30, 2008, 09:04:30 AM
Hello there
thanks
The 6N1P are pre-amp tubes but are generally used as a low-power tube in guitar amplifier (see www.ax84.com for some examples), and requires about 250V on its plate (the heater is 6.3V). I don't know how it can behave in starved-mode, but it is not intended to (well, neither the 12AX7!). You can try it, but I doubt it will sound great.
iorr
Try it.
This one is similar to the 12AX7, ECC 88 or 6922. You can see them in a lot of high end audio applications. For the heater you will need a regulated 6.3V.
Karsten
armstrom
Quote from: Jimmy-H on April 30, 2008, 05:41:35 AM
Would a switching power supply be sufficient? I'm looking at this guy to power both my 25W stereo power amp and two Tubecaster preamps... http://www.mini-box.com/80w-AC-DC-Power-Adapter-12v-6-6A?sc=8&category=13
i won't bother if it will have a lot of hum.
-Matt
Fender56
#473
-Matt
In order to reduce the hum from your power supply, you should look for a low line regulation value (about +/- 1% will be great). Higher this value, higher the risk of hum.
In your case, this value is not shown so it is hard to predict. I assume it will be fine (those kind of big adaptors are usually well regulated) but ask for the return policy, just in case!
puretube
A switchmode power supply rather causes "whine" than "hum", IMHO...
Just been debugging my Subcaster - again.
I can't seem to unite the voltage regulator for the heater with the main circuit. I know the voltage regulator works fine without being connected to the main circuit.
So - I thought I'd try bypassing the voltage regulator and running the whole main circuit at 6 volts.
Result - it works. Distortion, but obviously no boost as the voltage is too low.
I drove it a little harder with my LPB-1 - excellent.
Conclusions: this circuit will work at 6 volt  -with less gain.
As i can't seem to get the two parts together, I'm going to try this to get 6v for the heater from 12v:
The opamp can be anything really - 741, 1458, 351 etc
I've used it before to creat bipolar power for opamps and OTAs.
I will post my results.
Anyone care to comment?
iorr
Why so difficult?
Just place a 100yF acroos the DC jack. The pos. leg to pin 1 of an IC7812, pin 2 to ground, pin 3 to the circuit. If you want you can place another elco (47yf) on pin 3. So you get a regulated/cheapy and nice filtered power supply.
Karsten
Quote from: iorr on April 30, 2008, 03:47:38 PM
Why so difficult?
Karsten
That would give 12 volts at pin 3, the Valvecaster (12au7) heater is 12 volt - but the Subcaster (6111) heater is 6 volt - well 6.3 volt to be exact.
SirElwood
This is a EF86 preamp running on 12-24 volts. Should be interesting.
http://www.tg-music.com/EF86.pdf
awitee
hi i just built the valvecaster
it seems the volume is a bit weak, it needs to be at around 3 o clock to maintain the bypass level.. is it all this way or just mine?
and i dont think the gain is enough, i used a 100k log pot besides the 50k, is it because of this?
and i feel its too bassy what mods can i apply to it?
i used a 12au7 tube running off 9v
no problem with noise
i used a booster pedal before it, and it sound great
but as a standalone.. i dont know..
can you guys pls suggest some modifications? thx!
