adding a tone pot to a volume pedal?
Started by scott_v, January 08, 2008, 02:29:19 PM
scott_v
First off i made a simple stereo volume-like pedal using parts from a broken Digitech pds pedal.  it has one input and two outputs where each has a volume control (i used 100k pots).  To increase its capability I'm wondering if its possible to add a tone control pot to each of the outputs, meaning what pot rating would i use? 10k, 25k or 50k or ??? and would guess i also need a cap on of rating .333 uF or .1 uF or ??? Also need a hint on how to wire the tone pot, i think i only need to use two of the three pin points, point 2 would have the cap on it?
thanks,
Scott
Guitars: '72 Fender Telecaster Custom, Partscaster Strat
Pedals: ZVex Fuzz Factory, Boss TU-2, DIY SHO Boost clone, DIY EA Tremolo, Line 6 DL4
Amps: Fender Hot Rod Deluxe, Fender Champ (Silverface)
