Author Topic: Replacement Transistor?  (Read 3077 times)
Albot
« on: January 15, 2008, 12:54:19 PM »
I'd like to try different NPN transistors in this circuit although when i try some of them they sound realy bad.
I thought maybe that's because might need different bias?
Is there a general rule i can use to be able to try different transistors by adding a trimpot for bias or do i need to replace more then one resistor?
Would this work in all (most) circuits?
Gus
Re: Replacement Transistor?
« Reply #1 on: January 15, 2008, 01:03:07 PM »
Most Si small signal transistor should "bias up" with this circuit.
 Take the voltages of the bad and good sounding transistors.  Battery, Collector, Emitter and Base
