Lawrence- you do some incredible builds, very impressive.
Thanks Russ! Greatly appreciated!
What did you have to do to make the brick fit?
The original version of the BTDR-3H (hard plastic case) were 38x28x11mm and fit my original design like a glove, no modification to the brick necessary, room to spare. The new version is 38x32x11mm, making it almost 1/8" wider than the original version
The modification involved removing the outcase material from the side opposite the pins. I removed just enough to see the internal pcb and this was enough to fit my design. The new outcase material is soft and cuts pretty easily.
Here's what the original version looks like installed
I did have to modify the enclosure lid a little too
Divine intervention.
All the praying happened during the pcb layout phase..... well, until I received the new bricks... but that was mainly swearing...
At $15-$20 per brick, it isn't worth having to modify them to fit. I'll be buying up all the original version BTDR-3s I can find
