Bench Power
Started by 12milluz, February 05, 2008, 10:39:52 PM
12milluz
http://www.circuitspecialists.com/prod.itml/icOid/8238
Does that look like a good bench power supply? I'm buying a breadboard and wanted something like that. Is it good? ???
Quote from: Processaurus
You need a glade plug-in, in on a footswitch.  Kick on the big muff, then hit the air freshener pedal.
Visit my site: http://www.freewebs.com/12milluzmusic
Jered
  Looks like a fine choice.
  Jered
12milluz
mojo_hand
The 400 mA one would be fine for most solid state pedal projects, but that wouldn't be enough for most projects involving power amplification or tubes (heater filaments use a lot of current).  The 400 mA one does give a wider range of voltages, though, which could be handy... IF you're going to do something that needs >12v.
So, they both have their limits, which may or may not matter depending on what sorts of projects you do.  Either one would be fine for 95% of pedals, which neither use over 12v or over 400 mA.
12milluz
mdh
One thing you might consider is that it might be nice to have a bipolar supply for bench use, particularly if you plan to build circuits like R.G.'s Neutron (Mutron III workalike) or other filter/modular synth inspired stuff.  But if you're mostly interested in boosters & distortions, it's probably not a deal-breaker feature.
