Author Topic: IRF9620 instead of BS250?  (Read 1410 times)
gigimarga
« on: February 06, 2008, 10:45:56 AM »
hello,
i need an BS250 for a MOSFET Booster with positive ground, but the only P-channel MOSFET that i can buy here are some IRF: 9530, 9540, 9630, 9640 and 9620.
today i bought an IRF9620 because it was the cheapest and i want to know if it can be use in a MOSFET Booster instead of BS250.
thx a lot!
petemoore
Re: IRF9620 instead of BS250?
« Reply #1 on: February 06, 2008, 11:22:42 AM »
 Power mosfets have G/S capacitence which I guess [didn't compare data sheets] is higher than the BS250.
  I've used IRFxxx transistors and the high frequency losses didn't bother me, in fact I found it to be 'about right' and welcomed the LP filter effect.
  U say 'should' because if you used a socket it's worth just sticking one in there to see if and how it works...
« Last Edit: February 06, 2008, 11:25:50 AM by petemoore »
