Author Topic: Tonights Fuzz Experiment (includes sound clip and schematic !)  (Read 35113 times)
danielzink
Re: Tonights Fuzz Experiment (includes sound clip and schematic !)
« Reply #40 on: February 17, 2008, 03:24:31 PM »
This is the exact fuzz sound I wish the Octave Fuzz had. Nice and thick. Incorporate an octave function into the tone of this fuzz - make the octave switchable.......T'would be awwwwwwwwesome  ;D
Dan
Dragonfly
« Reply #41 on: February 17, 2008, 03:39:42 PM »
It seems you have gone over your bandwidth limit... Any chances you could send me those clips? email : raulgrell at gmail.com
http://www.aronnelson.com/gallery/v/DRAGONFLY-LAYOUTS_0/HEAVY+FUZZ.mp3.html
Focalized
« Reply #42 on: February 17, 2008, 06:01:49 PM »
I've been looking at it trying to follow the paths. Looks like a tricky thing to get good at, laying out the schematic. It seems like it would be right. I'm nobody to verify anything yet.
How does this look?  I realize that it's a little larger than it could have been, but I like to use 4 holes for resistors when possible to I can lay them flat.
Rick
Baktown
« Reply #43 on: February 17, 2008, 09:10:58 PM »
I have no idea what I'm doing when it comes to laying out schematics on Vero.  I would highly recommend that someone with more knowledge take a look before buidling this.
Rick
earthtonesaudio
« Reply #44 on: February 17, 2008, 09:40:11 PM »
The diode in the feedback loop I thought was interesting....I hadnt seen anyone doing that before. Ive run diodes of Q1's emitter, and the old Joe Davisson "Antiquity Fuzz" setup...but never in place of the resistor in the loop.
Good job coming up with the diode feedback on your own, but as soon as I saw that I remembered this:
http://www.geocities.com/tpe123/folkurban/fuzz/morefaces.gif
And I bet there's more mileage in there... caps, panning diode combos via AMZ "Saturation" type controls, etc.  Go crazy!
Dragonfly
« Reply #45 on: February 17, 2008, 09:42:13 PM »
Quite a bit different implementation of the diodes in the feedback loop, but I'll definitely have to try it and see if its an improvement. Ive seen that page probably 100 times, so it most likely just wedged the diode idea somewhere in the dark recesses of my (questionably sane) brain !  :D
brett
« Reply #46 on: February 17, 2008, 09:48:51 PM »
Hi
Absolutely....it would work as a gain control. A 2k trimmer might be even more useful.
The idea of using a pot on the emitter of Q2 as a gain control is a very good one.  But to keep the DC bias right, the pot value should be the same as the resistor (ie 1k).
You could change it to 2k and maintain the DC bias if you also doubled the size of the collector resistor.  This might also raise the maximum gain a little.
cheers
Brett Robinson
foxfire
« Reply #47 on: February 18, 2008, 10:02:39 PM »
i had this one on my board for a few days now. i haven't messed with it much though. partly cause i'm lazy but, mostly cause i don't think it needs much messing with. i tried a few different trannys but, i'm liking the 3904's. so far the only change i'm making is to add a fat switch. i found that it is a bit fatter with the 100k than it is with the 914. i also found that a 100uf cap from Q1's emitter to ground helps to fatten things up. so i'm using a DPDT switch to both switch between the diode and resistor and, switch the 100uF cap in with the resistor. all and all it think it's a damn good circuit. thanks for sharing it. now take down the schematic and get rich!
Focalized
« Reply #48 on: February 19, 2008, 12:41:26 AM »
Anyone able to verify the strip board layout? I love to play with it.
dxm1
  • Great Contributor!
  • Total likes: 2
  • Dave M - Orangevale, CA
« Reply #49 on: February 19, 2008, 01:13:25 AM »
I have a couple of questions about Rick's layout -
o   The junction of Q1's collector, R3 and R4 looks like it also connects to the emitter of Q2 - is there a track cut I'm not seeing?
o   Shouldn't C3 be 0.015uF, or 15n?
Otherwise, it looks good!
Focalized
« Reply #50 on: February 19, 2008, 04:10:33 AM »
Ah the layout didn't work unless i messed it up. Oh poop!
bipedal
« Reply #51 on: February 19, 2008, 06:34:01 PM »
Wow, those VMF sound clips are sick -- very cool.  :icon_twisted:  Made me want to crank up a Boris record and tune my guitars down a few steps.  (And add this build to my to-do list.)
Following up / clarifying an earlier post in this thread: if I exchange the 1K resistor off of Q2's emitter with a 1k pot, it could act as a gain/fuzz control?
Thanks,
- Jay
"I have gotten a lot of results. I know several thousand things that won't work." -T. Edison
The Happy Household; The Young Flyers; Derailleur
DS-1
« Reply #52 on: February 21, 2008, 07:35:19 PM »
It sounds AMAZING! I'll try to build it. Is the layout from Rick workin'?
Dragonfly
« Reply #53 on: February 21, 2008, 09:08:35 PM »
Thanks,
- Jay
You could set up the gain control exactly like a fuzz face :)
Dragonfly
« Reply #54 on: February 21, 2008, 09:09:00 PM »
I'll try to find time to check his layout tomorrow :)
DS-1
« Reply #55 on: February 22, 2008, 05:15:00 AM »
Thanks Dragonfly. I don't understand why "VOL 3" goes on 9v+ and what are red squares!
« Last Edit: February 22, 2008, 05:19:10 AM by DS-1 »
dxm1
  • Total likes: 2
« Reply #56 on: February 22, 2008, 05:28:11 AM »
Your confusion is understandable - the two are related. "VOL 3" does _not_ connect to "9v+". The red square is a trace cut. You must remove the copper trace completely wherever you see a "red square", to break the circuit.
This layout needs one more trace cut to be workable. Move everything from row 8 to row 14 to the right one row. Place a trace cut at D8. I haven't looked at since my last post, but I believe this would match the schematic...
DS-1
« Reply #57 on: February 22, 2008, 05:51:48 AM »
Oh, thanks a lot dmx. I'm a newbie, so I still don't understand some "tricks"! So, in few words, I need to "jump" one row ( move of one row everything is on row 8 ) and place a trace cut at D8, right?
« Last Edit: February 22, 2008, 06:39:12 AM by DS-1 »
« Reply #58 on: February 22, 2008, 07:24:15 AM »
yes that's right
DS-1
« Reply #59 on: February 22, 2008, 09:54:17 AM »
Thanks. I'll try to make it as soon as I can!
