hi,
im in the process of debugging a PT80 i just built for a friend (its the newest version of the project, from GGG with the charge pump)
this is what ive found so far:
im getting a normal guitar signal when both bypassed and engaged, but no delay.
the circuit started to get hot, and i was getting a burning smell
(at which point i turned the unit off).
also, the led looks too bright.
my immediate thought was that it must be a short, and after checking through everything, i did indeed find one (between 2 tracks), but after correcting it, the pedal is stil acting the same.
next i went through the resistor values, and they were all ok, except there is a 4.7k listed on the bill of materials, but its not on the circuit layout?, in fact, there are 30 resistors listed on the bill of materials, but i can only count 28 on the layout.
ive triple checked polarity on the electrolytics and diodes, orientation of the IC's and all offboard wiring is as it should be.
i cant take any voltages, as im afraid of doing some damage (if i havent already
), so if anyone has any ideas, you would be helping me greatly
