Hey all!
I got this Whammy II in from a friend; he dislikes this unit mainly because it is unbearable to play...... ok, what happens:
- It powers on perfectly and works flawlessly
- but when you tap the outside of the unit, the metal casing, the input level LED starts to burn and you hear some noises / crackling
- if you use the threadle sometimes you touch the casing and this causes more crackling, etc
- Sometimes it sounds like the unit is unplugged, sometimes it is boosted in volume.
what can be wrong here?
