Zombie Chorus debugging layout
Started by LiquidSteel, April 23, 2008, 01:42:07 PM
LiquidSteel
Hi
Just finished the Zombie Chorus, but was unlucky with this layout:
http://www.aronnelson.com/gallery/main.php/v/Xaviers-shrine-of-noise/Layouts/Zombie_001.gif.html
After checking it with the shematic I found some mistakes:
- there are two ground lines: the connection is missing
- pin 3 and 4 (IC2: MN3007) are grounded on the layout, but the shematic shows, that pin 4 and 5 must be groundet
- there is no connection between the input of the MN3007 (pin 3) and the output of the Oamp (pin 1)
I visualitzed the mistakes on following layout:
http://de.geocities.com/masterdiy/zombie2.jpg
But it's still not working. Im getting a bypassed guitar signal with no effect. This is the only layout for breadboards I've found and I want to fix it.
Here is a picture of my build:
http://de.geocities.com/masterdiy/layout.jpg
And here the shematic:
http://www.hollis.co.uk/john/zombie.jpg
Doest somebody build it with this layout and get it working ? Can somebody find more mistakes in the layout ?
LiquidSteel
is there somebody who has build this effekt with good results ?
LiquidSteel
I found the last mistake !
- pin 14 of IC1 have to be connected with V+
Now everything works great. So be carefull if you use this layout and attend the mistakes !
Bye
