Ruby Idea
Started by kurtlives, May 18, 2008, 04:27:08 PM
kurtlives
Here's my idea for a custom Ruby...
Its two Ruby circuits powered by a 12V transformer (regulated and filtered). The two circuits will be switchable, one will be a standard(ish) Ruby the other will have Bassman mods.
Right after the input and before the Ruby's will be a Valvecaster http://www.diystompboxes.com/smfforum/index.php?topic=63479.0 . It will be like the on-board distortion. It will be switchable so its not always on. Transformer + tube = cool pedal.
This will all be mounted in one enclosure. On the enclosure will be a speaker. There will be a switch though to select between the speaker and a speaker out jack.
Here's a diagram to help visualize it all....
Anyone have any suggestions or see any issues. Any input would be good.
My DIY site:
www.pdfelectronics.com
kurtlives
I realize now that I need output selectorswitch instead of that switch to select Ruby's.
My DIY site:
birt
just use a switching jack for the speaker out instead of that seperate switch
http://www.last.fm/user/birt/
kurtlives
I was told about these...where can I find one and how do they work?
My DIY site:
jakehop
Switching jacks can be bought at most stores. Banzai carries them, I'm sure Mouser does too!
Be sure to only have one Ruby connected to the speaker at a time. Problems can arise when having two amps in parallel on one load, when not made for bridging. Have a DPDT switch between the valvecasters output and the ruby, and the ruby's out and the speaker. Use a 3PDT if you want a LED.
Jake
Wouldn't it be possibe to use just one Ruby and have the Bassman mod switchable using a 3pdt, switching over the two cap changes and the one resistor change?
ambulancevoice
i have an easy way of doing this
ill draw you up a schematic
give me a sec
kurtlives
Quote from: frequencycentral on May 18, 2008, 06:28:39 PM
Probably but that's not how I roll. 8)
My DIY site:
dxm1
ambulancevoice
#9
i doubt thats TO MUCH for you  ;)
but if you want to switch between two circuits even though there the same except for two caps
then may i suggest a 3pdt! and maybe make it a rack mount unit with a footswitch! man that would be fun
like the R2D2 (two Rat's in a rack mount)
kurtlives
Quote from: dxm1 on May 18, 2008, 07:11:28 PM
Here's one way...
How does this look? Thanks so much for the schem!
My DIY site:
kurtlives
Also the Ruby looks almost identical to the Noisey Criket. Besides the tone control (which I hear sucks) and the grit switch they are identical..well almost (3.3K vs 3.9K and what not).
Anyways is that grit switch a fun feature?
My DIY site:
kurtlives
I was looking at the LM386's datasheet. It seems the amp really would operate best with a 16ohm load. I plan on using a 4ohm speaker, my IC will get a bit hot then me thinks.
My DIY site:
