amp diy, need help
Started by awitee, June 15, 2008, 02:11:33 AM
awitee
ive been planning on making a small amp, like a noisy cricket or other mini small watt amps
but im not really well versed in amp making so i have a few questions
the noisy cricket is the preamp ryt? so i just need to plug the out to a speaker cabinet?
how do i make a cabinet for the preamp? what i know is that a speaker has 2 lugs, what do i do with those? do i have to provide power to the cabinet/speakers? how do i wire noisy cricket to the speaker? sorry for the many questions.. i just dont have enough knowledge on this, but i really want to make one, i also tried searching, but i cant seem to find any answers
wavenator
listen
the speaker has 2 lugs
+ and -
the + goes to the "output" point on the board (on the circuit)
the - goes to the ground of the circuit
the noisycricket is a preamp+power amp
its 2 in 1 ^^
you build it and connect it to a speaker and you got an amp to practice with
you dont have to provide any power to the speaker
awitee
wwooww i see i see
tank you very much for the quick reply
soulsonic
awitee
yup thats the one im planning to build
i just needed more info on the speaker lugs/cabinet power
Good advice Dano12 gave me: get a JRC386 if you can, its better than the LM386. Also there are four versions, N1, N2, N3 and N4. N1 is a third of a watt, N4 is one watt. So get a JRC386/N4 if you can.
awitee
it says that the noisy cricket is 0.5 watts
how do i increase the wattage of the amp?
Quote from: awitee on June 15, 2008, 07:46:26 AM
As above - use an N4
awitee
hmm i doubt that my local electronics shop has those, could i use any type of audio amplifier ic? because i think they have a lm838 which is described as an 8watt audio power amplifier, could i use this?
LM838 - that would be a completely different schematic I'm guessing. I did a quick Google on LM838 and didn't come up with anything.
awitee
really? hmm i huess ill just go with the lm386N thats available hehe
btw, besides the changing of c2 to 1microF, wat other mods can i do to make this a bass amp?
Quote from: awitee on June 15, 2008, 08:42:00 AM
You can always build it with what you've got and just swap out the chips if/when you get a JRC N4 - assuming you socket the I.C. - which you should.
awitee
hmm dats ryt, thx thx
as for the bass mods?
