i built it, it's good. nice and subtle
This is an interesting fact. I recently built this and immediately noticed that the ALL of the pots are wired REVERSE! Also, that trim pot (VR104) is not called for on the schematic. Also, you are missing a resistor from the MN3207 Pins 7 & 8 to ground!
Did you verify this but fail to post any of the changes?
I am still working on getting my LFO to wobble. All else seems fine as I get the "warped" sound when adjusting the Width and Delay pots but, the Speed pot is non-existant and I get no voltage swings on my LFO IC pins. I used a TL022CP as called for on the schematic. I am gonna try different Op Amps and see if I can get it to "turn over!"
I also matched (2) 5088 transistors to replace the 2SC2583F that is used on the original units. I matched them at an Hfe of 510. I read in another thread that maybe they should be tested for Vbe but I am hoping it is not that strict in tolerance.
