green russian big muff transistor voltages ?
Started by znowman, July 22, 2008, 06:09:15 PM
znowman
have just built a green russian from the GGG site, and its too quiet.  ive just had a look through the GGG project pdf's and cant seem to find the transistor voltages listed there or by searching these forums
anyone know what they should be ?  (ive used 2n5088's btw)
tia
  BJT Gain stages, sorta regular..
  Base above emitter by a diode drop, collector toward the middle of the power supply rails [so it can swing +/- 'freely'], base and emitter should be 'near' ground.
znowman
thanks, wasnt sure the russian would have the same voltages as the normal muff, i'll check what im reading when i get chance.
i'll also compare your info petemoore to what im getting...
thanks again !
