First "EYE" check of the VERO
Tht's what I can do for now, as I haven't got all the parts needed to build that - It seems quite correct at a first glance, maybe I am not so sure about that SPEED 3, as you wrote...It should be 47k res-->SPEED pot lug 3 and LUG 1&2-->ground.
I'd erase that jumper to ground...
Also...You didn't write that the last track is for ground too, so it should be connected to the other ground track - maybe it's the same long jumper that doesn't go the the track labelled "l" but to the last labelled "o"
