Author Topic: AMZ Big Muff Mid mod  (Read 3588 times)
criss
« on: August 27, 2008, 11:26:53 AM »
The Mid control mod calls for this
Replace C1 with a 22n cap Ive done this
Replace R2 with a 22k to 25k potmeter (wired as a variable resistor) with a 1k resistor wired in series , not sure if ive done this correct .
Any input would be a big help see pic
Thanx
John Lyons
Re: AMZ Big Muff Mid mod
« Reply #1 on: August 27, 2008, 11:41:47 AM »
The pot is wired correctly as a variable resistor.
john
Basic Audio Pedals
www.basicaudio.net/
petemoore
« Reply #2 on: August 27, 2008, 11:52:12 AM »
  Measure across them with 200k setting on DMM.
  Values should range between 1k and
  1k + whatever the pot actually measures [pot probably measures a bit less than marked value.
  Say the pot measures 21.5k, max resistance setting will be 21.5k + 1k = 22.5k.
criss
« Reply #3 on: August 27, 2008, 12:30:44 PM »
Thanx fellows
Measured  across the lugs and got 00.0 when the pot is full left and 23.5 when i turn pot full the other way
Should i be soldering the 1k resistor across the lugs as shown or from green to green  .
Thanx again for your help
kurtlives
« Reply #4 on: August 27, 2008, 12:38:25 PM »
No you want to attach the 1K resistor in series...so just to one lug. Where ever the signal is going in you want the 1K resistor in series with it.
criss
« Reply #5 on: August 27, 2008, 03:01:26 PM »
Thanx all  Up and running
I must also say what a fantastic mod this is  .
Bucksears
« Reply #6 on: August 27, 2008, 05:21:27 PM »
Quick question: is this the AMZ 'Presence' Mod for the Big Muff?
criss
« Reply #7 on: August 28, 2008, 01:23:21 PM »
Correct mate AMZ 'Presence' Mod for the Big Muff
