DON'T THROW OUT THAT LIGHT BULB !!!
Started by Dragonfly, September 01, 2008, 01:26:46 AM
rotylee
Maine law does not allow fluorescent bulbs, including CFLs, to be disposed of in the trash because they contain a small amount of mercury.
obelix
how does one go about opening these bulbs?
demonstar
Quotehow does one go about opening these bulbs?
I also noticed the ones we have here in the U.K. have no screw. They appear to be sealed.
"If A is success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut"  Words of Albert Einstein
Dragonfly
Theres a ridge (see photo) around the base - if you carefully insert a flathead screwdriver in the ridge and twist it sideways, you should be able to pry the top and bottom apart. Sometimes you have to do this in a few places to separate the parts.
demonstar
QuoteTheres a ridge (see photo) around the base - if you carefully insert a flathead screwdriver in the ridge and twist it sideways, you should be able to pry the top and bottom apart. Sometimes you have to do this in a few places to separate the parts.
Thanks, I got you. Now I've just got to wait for a bulb to die.  ::)
...................I can see legions of DIYers sitting in darkened rooms building effects..................
McGhie
Oh wow Dragonfly (and the people who started tinkering with this!!!) this is just fantastic! You made my day with this thread! ;)
Quote from: frequencycentral on September 02, 2008, 02:54:27 PM
:D
Builds in process: NPN Boost, Atari Punk Console (standalone), Underfuzz
col
See Dragonfly's answer but some are glued and you can't prise them apart. To avoid poutting strain on the bulb and potentally breaking the glass part containing the nastys I go around the seal with a junior hacksaw, then you need to cut the two wires that go from the circuit board to the bottom of the glass part. The bottom of the bulb complete with circuit board than falls away. You then unclip or unscrew the circuit board and cut the wires that go to the terminals. Then the scavanging starts!!!!
Col
Fl!P
I was looking at this picture of CF ballast and saw those 2 carby comp resistors and thought:
Woah, mojo!
Also, I tried using the transistors I found (13003, designed specifically for ballast) and they only half worked.
I used them in a NPN Fuzzface circuit with 'Roger Mayer mods'. They have gains of 17 and 20.
It really didn't sound any good, crackley with no sustain.
Though, If I get a breadboard, I'll see if I can get a decent sound out of them/bias them.
Completed Builds: Gus Booster, Plexizer, BSIABII, Si/Ge Fuzz Face w/ RM Mod, Orange Squeezer
To Do List: Valvecaster, Small Clone, Jawari
For Sale:Marshall Footswitch
GREEN FUZ
I`m amazed you can get so many useful parts out of these bulbs. I`m also surprised that there aren`t any SMD`s.
runmikeyrun
Quote from: Sir_Ian on September 01, 2008, 02:32:39 AM
you forgot something...They also have Mercury inside them.
Andrew K, this is how he came to be insane enough to figure this out!
j/k, this is a great idea.  How can you test the transformers to find out what application they can be used for?
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
ambulancevoice
Quote from: Hanglow on September 01, 2008, 08:09:07 AM
now, whoever is first to reuse the pcb gets extra brownie points :D
even more if you reuse the bulb and its base
col
I was thinking about this last night. What actually goes when one of these stops working as so far I've not pulled anything from the circuits that doesn't work?
Col
I was wondering that as well, presumably like with normal fluorescent strip lights it's the tube that goes not the electronics.
asfastasdark
Could someone trace the PCB of one of these lamps, and make a schematic? I wanna see what effects me or other people can come up with... lol. It's worth a try.
col
"Could someone trace the PCB of one of these lamps, and make a schematic? I wanna see what effects me or other people can come up with... lol. It's worth a try"
All the ones I've had have had a different circuit from different manufacturers so it might not be that useful. If I get one soon I might try and do it.
Col
comfortably_numb
How would one go about testing for the pin-out of the transistors?  R.G.'s site has an article on gain testing, yes?
Thanks,
Joey
frank_p
Quote from: comfortably_numb on September 07, 2008, 02:26:51 PM
Thanks,
Joey
http://www.repairfaq.org/sam/semitest.htm
asfastasdark
Just imagine popping two transistors found in the bulb into an OD circuit, and you get amazing tone, all from some obscure industrial transistor that no one has ever heard of!  ;)
oldrocker
I use those bulbs in my magnifying light when building pedals.  Recycling at its finest.
