Big muff rustling sound
Started by vasso123, January 30, 2012, 11:02:06 AM
vasso123
Update: I resoldered all elements around 1st two transistors, I again have this noise, it's like 50hz noise, I don't know. But i figured that turning the gain pot almost removes all the noise. At full gain there is a lot of noise, at middle there is no noise, at zero there is noise but less than on full.
What next?
runmikeyrun
have you used an audio probe?  Start at the input jack tip, and work your way through the circuit.  See where the noise starts.  That's where your problem is.
Can you post clear, high resolution photos of the top and bottom of the board?  That will help us see how the components are laid out and what the soldering looks like.
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
vasso123
It was a power supply fault, I use a psu from computer,and I didn't remember to filter the output voltage. After putting a larger cap, the problem was gone,thanks for the help guys :)
