im making a stompbox tonight
Started by bassmasta17, November 14, 2008, 05:39:39 PM
oskar
Those are cutmarks. You also need to cut under the IC.
The layout shows the stripboard from the component side. The copper tracks are then
on the bottom so you need to take that into account when cutting ( mirrored )
Load the picture into paint and flip it upside-down.
bassmasta17
im using some pc board that i have. their are no tracks just dots so that would not be necessary for building it with the pc board correct?
Any thoughts on the led problem?
thanks
i play bass.
www.freekbass.com
bassmasta17
thanks that all helps alot. if i get anymore problems i will ask them here.
i play bass.
www.freekbass.com
oskar
Quote from: bassmasta17 on November 16, 2008, 07:44:37 PM
Sort of. You wouldn't need cutting but...
The layout is intended for stripboards and nothing else...     :)
To use this layout with perfboard, you need to connect components connected by the copperstrips with wire instead.
  There's probably a perfboard layout for the Muff Fuzz around here somewhere.
bassmasta17
Would i be able to just use wire and solder what is inline with the row and make it that way?
i play bass.
www.freekbass.com
bassmasta17
It is two OP-amps in one package. The schematic says 4558 but you can swap with TL062, TL072, TL082...
Price? Not a lot... none of the components are exotic.
Layout intended for...
http://diystompboxes.com/zencart/index.php?main_page=product_info&cPath=5&products_id=17
[/quote]
what would swapping them out mean. I would prefer a heaver tone as i play bass.
ok shopping list
resistors
680k x2
10k
470k
100k
capacitors
100nF
10nF
10uF
ICs
4558
What are the D1 and D2?
i play bass.
www.freekbass.com
bassmasta17
sorry diodes slipped my mind.
i think i will wire both kinds in then use a switch to change them. anybody have any problems that could occur with that idea?
i play bass.
www.freekbass.com
dschwartz
man, you should read some electronics before trying to build something..
For a start, you should read (and learn) this:
http://library.thinkquest.org/10784/circuit_symbols.html
Tubes are overrated!!
http://www.simplifieramp.com
8mileshigh
Daniel is right.  Do a bit of reading and start with a simple circuit like the Bazz Fuzz or the beginner booster project.  Check out the step by step guide here on the site.  Small Bear's Tweak-O is how I learned about assembling a circuit.  Check it out.
Chris
Builts completed: Tweak-O, Fuzz Face Si and Ge, Rangemaster,Fuzzrite Si & Ge, Bazz Fuzz, L'il Devil Fuzz, Bosstone one knober, Bosstone Sustainer, Cream Pie, Kay Fuzztone. http://www.myspace.com/chrisdarlington
bassmasta17
ive been reading a lot about that lately. about 40 mins a day for about a week. (this is for a advanced industrial technology and trades class(AITT))
i have worked a lot with house wiring over the summer. I have never used IC's before. So i have basic knowledge of the subject just not anything major like this. A buddy of mine is helping me build this and hes build before. he doesn't know what to do with the GE or SI problem of having a switch to switch them. any problems? My shopping list looks good right?
I might go tonight, i have to get a another converter box. :icon_lol:
i play bass.
www.freekbass.com
bassmasta17
i know i shouldnt be doing this but would... ughhhg radioshack have the IC that i need?
too much junk parts and no one knows anything their.
i play bass.
www.freekbass.com
  Probably they have the TL082 Dual Opamp.
bassmasta17
thanks im going tonight to buy some parts probly start building tomarow. i have some diodes form something called fabulous fred. it was a game that made diffrent sounds from what you played and such. i might use that i dont know yet. also any ideas on me using a swicth to swicth from ge to si diodes? ifso have a schematic. thanks.
i play bass.
www.freekbass.com
bassmasta17
should i use stereo out in mono 1/4 jacks or can i use both mono?
i play bass.
www.freekbass.com
bassmasta17
im leaving in like 5 mins. i hope some one sees this. i will probly have both mono.
i play bass.
www.freekbass.com
GREEN FUZ
Get 1 stereo (in) and 1 mono (out).
bassmasta17
Quote from: GREEN FUZ on November 21, 2008, 03:55:34 PM
stero in mono out got it. thanks alot man relly apresheated.
like my spelling.
i play bass.
www.freekbass.com
