Questions about Q-Tron and others envelope followers...
Started by gigimarga, November 18, 2008, 06:42:07 PM
gigimarga
Hello,
I am a big fan of envelope followers.
First, i borrowed from a friend a cheap Ibanez Soundtank Autowah. It sounded very interesting to my ears (even with his poor quality sound), so i'd built a Nurse Quacky which i'd liked very much (the effect, of course :) ).
After that i built a improved MXR EF 440.
Both of them (Nurse and MXR) was exchanged and, after all, i bought an older EHX Q-Tron which sounds amazing...i spent few hours every day for almost a week to play with it and i think i have much more to discover.
After a long struggle i finished a Maestro FSH which remains No.1 in my stompboxes top!
Last week i built a hard modded EHX Bassballs (thx Mark Hammer again...) which i like very much, too.
So, my questions are:
1. It is possible to simulate the EHX Bassballs using Q-Tron (my pedalboard have 210 x 80 cm and it's full!!!)?
2. It is possible to modify the EHX Q-Tron to obtain a distortion/fuzz which has the amount of distortion controlled by the force of picking (my beloved dream...like Boss DN-2, but analog)?
3. Is there any others stompboxes of this type which sounds different from what i have (like Mutron, Brassmaster, etc.) which i deserve to build?
Thx a lot!
Unbeliever
Quote from: gigimarga on November 18, 2008, 06:42:07 PM
Depends, how picky are you about the accuracy of a 'simulation'?  :) The Bassballs and Qtron have different filter topologies, and in fact different number of filters (two in parallel that can be tuned to different frequencies vs one), so the answer here is no, realistically speaking.
Yes, if you are happy with a fuzz-sound that would be similar to that obtained via the Bassballs; you need to take a tap from the FWR circuit. I think EH schematics are banned from here, so I can't give you more details.
If you have a Q-tron, I wouldn't bother building a Mutron III clone. The Q-tron is an improved MutronIII, and has the same filter arrangement (state variable) and hence a very, very similar sound.
gigimarga
Thx a lot Unbeliever!
I tried a little to simulate the Bassballs using the Q-Tron and i had no good result, but now i have the confirmation.
Anyway, it's possible to add another filter to Bassballs? How it will sound?
If you want to help me to obtain the fuzz from the Q-Tron i can send the schematic to you on the email (if you want).
Thx a lot again!
Unbeliever
Quote from: gigimarga on November 19, 2008, 12:45:15 AM
Sure, you can just duplicate the circuitry that is there for one filter section already. The two caps determine the base frequency.
How it will sound?
Try it and let us know. It might be a good example of the law of diminishing returns... three 'balls' may not offer significantly more performance than two.  ;)
Try tapping off the signal at the junction of R29, D2 and R31 - you'll want to use a DC blocking Cap (eg 100N), and depending on level you might wave to add a pot as a volume control. Feed all of this via a 4k7 resistor into Pin 3 of U4A (if you want the distortion to go via the filter). This is just from a quick look at the schematic (which I have, thanks), some trial and error with signal feed points and destinations should give interesting results.
Please post back what you find out.
B Tremblay
B Tremblay
runoffgroove.com
The Bassballs has two unique traits.  First, the attack time is very short; short enough that you mostly hear the decay portion so it seems to only sweep downward.  Second, the peaks of the two filter sections are staggered apart in a characteristic way.  On the builds where I can tune both filters, many of the settings reslt i sounds which do not sound at all like a Bassballs.  Good sounds, but not THAT sound.  Perhaps it would be possible to mimic the Bassballs with the rackmount Bi-Filter, but just about every other commercial floorpedal I know of uses a single filter with a single resonant centre or corner frequency.
gigimarga
Quote from: B Tremblay on November 19, 2008, 07:35:50 AM
Are you using guitar or bass with the Bassballs?
Thx a lot! I use Bassballs with a Squier Affinity guitar (not a bass).
gigimarga
Quote from: Mark Hammer on November 19, 2008, 09:46:26 AM
Thx a lot again Mark! It's very clear now!
What about a BOSS AW-2? It's interesting?
DougH
Pretty good article, but I hear from reputable sources that the guy who wrote it is a class A putz. :icon_wink:
This article, while older, is a little more authoritative. http://www.elliott-randall.com/ecf.htm
This makes a good read too: http://www.beigeltech.com/articles/vintage/vintage1.html
Finally, this one looks real interesting too: http://www.beigeltech.com/articles/ics/ics1.html
B Tremblay
Quote from: Mark Hammer on November 19, 2008, 10:52:34 AM
Well, everybody knows that class A is where the mojo resides...
Over the summer, I spent some time with the Bassballs circuit.  Here's a schematic of the minor mods I made:
First, I jettisoned the fuzz mode.  Then I added the resonance switch, which changes the filters to true twin-Ts for more pronounced peaks.  Finally, I added the filter blend pot at the filters' outputs.
Thanks to Topopiccione for its Bassballs page.
B Tremblay
runoffgroove.com
Funny, I pretty much jettisoned the clean mode on some builds. :icon_lol:
That resonance mod looks very interesting, especially since it only involves a toggle.
I would strongly encourage you to explore varying the 330k decay resistor.  Faster decays make the effect sound much more synth-like.  That, and greater resonance could make a nice one-two punch.
B Tremblay
Quote from: Mark Hammer on November 19, 2008, 03:12:28 PM
I toyed with different values for the 4u7 cap, but didn't consider the resistor.  I'll definitely explore that option, though instant gratification tinkering isn't much of an option during this time of year.  Sure, I can build a fire in the shop, but I much prefer being able to scoot out there whenever inspiration hits.
Can you please keep some of that frigid air in Canada where it belongs, Mr. Prime Minister?  At the very least, some of that lake-effect nonsense?
B Tremblay
runoffgroove.com
I work 3 blocks from Parliament Hill. I'll trot over lunch-time tomorrow and see what I can do.  Not making any promises, though. :icon_wink:
orangetones
Hey Mark, This is off topic, but I live here in Ottawa too!  /Neato!
gigimarga
Quote from: B Tremblay on November 19, 2008, 02:06:25 PM
Thx a lot all again!
I used the filter blend pot as you described and sounds very good. I still keep the fuzz mode because i like it :)
earthtonesaudio
#16
I was working on a similar filter design to the one B Tremblay posted (dual parallel twin T filters) a while ago and found that BS170s gave less distortion and more range than any of the BJTs I tried.  You might want to swap some FETs in there to see if you like the sound.
Note: One big difference, I was driving the FETs with a PWM, not a control voltage.
Celadine
gigimarga
Quote from: Celadine on November 20, 2008, 10:47:13 PM
Heres a page about modding a BassBalls, schematics at bottom of page:
http://members.tripod.com/urekarm/synth/fuzzyballs.html
:D
Thx Celadine...i know the schematic, but i think it's too complicated... ::)
StephenGiles
