Well, well. I wake up this morning to see this. Seems Charlie was really on top of this one. Nice work, Moose!
Does this mean you are ramping up for a new board...
That's what this R&D is all about.
...or will I be able to finish my ad/a on one of the made for SAD1024 revisions.
If you have an "old" board; and can't find an SAD1024; the retrofit circuit is relatively easy to build and set up.
Very good news! I've been waiting for this.
Are you going to be adding this to your multi f/x extravaganza?
Curious as I am, are there soundclips available? Is there a PCB?
It sounds just like the other 3 A/DA's I compared it to. There are plenty of soundclips of the A/DA out there. PCB soon come.
Now look here - do you mean to tell me that I've got to make one of these too??
Of course Sir! You know one can never have enough of these...
I remember that the parts used in Mike Irwin's 1024 version around the BBD were chosen for good reason, has this been invoked around the 3007 or is it the standard circuitry?
Except for the 100k trimpot at the 3007 output (more on this later), it is the standard circuitry as far as the A/DA revs. 3 & 4 go. The MN based versions. After looking over the 3010 & 3007 datasheets I realized they had very similar, and in most cases, identical characteristics. I figured the 3007 should be as close to a "drop in" replacement as there was going to get. Except for the need to double the clock frequency, of course. The input, Vdd, Vgg, Gnd, and clock setups were taken directly from the A/DA rev3/4 schematics. So much for originality
. But hey, at least I'm honest.
The output trimpot was decided upon after some trial and error. When all was said and done this seemed to be the easiest and most intuitive method for me (it also sounded the best). EE guys so eloquently refer to this as an "Easter egg hunt". For me, it's "R&D"
But it would be great if some of the more knowledgable folks here would give a look and chime in with thoughts, ideas, analyses, suggestions, etc...
Big time +1.
C'mon; I know you're out there with rage in your eyes and your megaphones!
BTW; for accuracy's sake; When I tested this in my unit; the R that's marked 150R was really 250R. Also, I would change that 10u cap for 22-33u.
That's it for now. More later.
All the Best,
Dave
