Hey all, long time listener, first time caller etc etc
Been building pedals for 6 months or so and fell in love with the Magnus Modulus project as soon as it was posted up by FF_Pedals. Seemed quite complicated with my limited experience but, while I'm still in kindergarten theory-wise I
can triple check things and follow a plan with the best of them
I finished the enclosure last year prior to getting the board from the US and ordering the parts. Started on the innards early this month.
I'd intended a fully polished finish, something different from my usual painted approach, with a label on top. Well, I spent hours and hours filing, then sanding and finally polishing the box and eventually got it looking like chrome. Unfortunately, after I'd stuck the decal on and begun adding the final polyurethane coat, all that shine went south. It's ended up as a sort of burnished, slightly greenish metal finish that I'm still pretty happy with so all's well.
It's the most complicated pedal I've built and yet, due to Nathan's / FF_Pedals excellent documentation, the most fun. Oh, and it fired up first time, thank God I didn't have to debug this bad boy.
Some idiot accidentally ordered a couple of capacitors suitable for use as part of the national grid and yet was determined to make them fit as a personal challenge... see if you can spot which ones :wink:
It sounds fantastic and is a lot of fun to play with, working out what dial interacts with what. I'd always assumed that I'd be using it pretty clean but found that quite a fast tremolo rate coupled with a nice scuzzy fuzz pedal sounds brill. Lots more to discover.
I decided that this pedal was going to be built practically rather than prettily and so went for stronger stranded wire rather than the more easily positioned solid core stuff and also made each run long enough that I could hinge the board up and get at the underside to tweak things if need be. I have slightly more background hiss introduced by turning the pedal on than I'd like so need to look at isolating that problem and minimising it but, frankly, I'm having a lot fo fun just playing it at the moment, so that can wait.
