Barber Electronics says happy holidays with a circuit!
Started by David Barber, December 18, 2008, 08:34:06 PM
Ben N
Anybody know where to find a datasheet and/or a source for JRC 072BD?
stibu
JRC stands for Japan Radio Corporation. A few years ago they changed their name to New Japan Radio or NJR for short.
Their site is here: http://www.njr.co.jp/index_e.htm
Here is a link to the part you are looking for:
http://semicon.njr.co.jp/njr/hp/productDetail.do?_isTopPage=false&_productId=6&_moveKbn=PRODUCT_DETAIL_MOVE_SPEC
flo
Any dual opamp will do. For instance a low cost TL072 or a high cost OPA2604.
sixstringphil
Anybody successfully printed Madbean's layout? It says 600dpi but opens in Photoshop as 72dpi and it's already huge.  Changing resolution to 600 makes it enormous.  Help??
Phillip
John Lyons
Open it up in PS and select a .1 grid in preferences.
Set the resolution to 300 and mode to RGB.
Select and then scale it while holding down shift.
The Pins of the IC will line up with the .1 per inch grid
when it's the right size.
Either that or email me and I'll send you the layout sized
correctly. :)
John
Basic Audio Pedals
www.basicaudio.net/
bean
In Photoshop: use Image Size - uncheck 'resample image' and type in 600 for the resolution. It will be properly sized.
sixstringphil
Thanks John and Brian! Both solutions worked well! Can't wait to get started on this.
Heemis
Just breadboarded this circuit and I love it!  It's all I could ask for in a transparent overdrive.
Since I like to keep things simple, I was hoping maybe Mr. Barber could enlighten us with the factory default settings for the trimmers in the circuit... perhaps even suggest stock fixed resistor values as he does for the mid control.
Again, thanks for this fantastic circuit!
deaconque
Just finished mine today (from Madbean's layout, thanks  ;)).
tuckster
I built it and it sounds good. TR1, TR2 and the Tone Pot doesn't change the sound?! I checked the traces, I checked the pots the ..everything.. I even resoldered the damn trimpots because I thought I fried them.
The sound (as it is) is very cool with out the use of the obviously not working pots but ar ethere any suggestions about what could be wrong?
I used this layout: http://www.aronnelson.com/gallery/main.php/v/slackers-stuff/diyltdboard.jpg.html
Would it be ok to post some voltages or any other stuff? I don't know what could be wrong.
deaconque
Quote from: tuckster on May 29, 2010, 11:30:41 AM
I had the same issue when I built mine.  I think I adjusted some values inside slightly but I can't remember for sure, it didn't really help.  This pedal is what it is and doesn't do a whole lot else but it does sound great.
tuckster
Yes in deed. But somewhere I read about the flexibility " it is so flexibly and can produce a lot of different sounds because of the trim pots" - that's simply not true :D
Maybe I have to buy the original to get this flexibility. But to be true - I don't need flexibility because, as mentioned before, it sounds really good.
Just1More
The external tone control is very subtle.   Presence is pretty subtle but Mid and Bass trimmers should make a noticeable difference - mids particularly.
mikemaddux
All mine work fine....tone control has a pretty big sweep on mine......presence doesnt do that much though...
Completed Builds: A lot...
Brymus
Quote from: deaconque on October 25, 2009, 04:45:57 PM
I really like the graphics on that enclosure.
What type of enclosure is that ?
deaconque
That's one I picked up from Experimentalists Anonymous a while ago.  Not bad for $4 but it's a much harder metal to drill through than the standard box.
Thomeeque
 Hi fellas!
I'm just curious, was somewhere already mentioned what are "factory settings" for PRESENCE and BASS trimpots?
Thanks, T.
Do you have a technical question? Please don't send private messages, use the FORUM!
BoxOfSnoo
My Dropbox referral link - bonus 250MB of space for both of us if you use it
tuckster
BoxOfSnoo
#99
Quote from: tuckster on August 04, 2010, 06:44:16 PM
Quote from: BoxOfSnoo on August 04, 2010, 05:38:35 PM
Quote from: bean on December 21, 2008, 02:14:38 PM
Here is rev. 1.0. Enjoy.
Is there any mirror of this anywhere?  Or an updated PCB?
http://www.diystompboxes.com/smfforum/index.php?topic=83838.msg697351#msg697351
The image is small but maybe madbean can provide a proper resolution :D
Thanks!  I fought through it this morning and came up with this:  (Not verified yet)
Parts list the same as on MadBean's layout.  Any gross errors anyone can see?  (I fixed a little one on the bottom-left corner, plus colored the traces so I could see what was +9v, GND, and +4.5V)
