Midi presets
Started by Dimitree, January 13, 2009, 10:04:48 AM
Dimitree
Hi guys,
I got a Boss DD20 delay pedal, this unit has 4 presets + manual preset, you can change them with a press-button on the unit the scroll the presets.. I'm wondering..it is possible to add a Midi control over these presets? just like the one on the Whammy.. Once I read that someone did that to the Line6 DM4, so I think it should be possible to do..
iaresee
You can add an external footswitch to the DD-20 that you can assign to switch presets. This could be used to MIDI-ify the pedal: you'd use a MIDI -> non-latching relay and plug the relay output in the f/s input on the back of the DD-20. You could do the MIDI controller on something like an Arduino -- there's an Arduino MIDI -> CV project here.
Dimitree
thanks,
but sorry, I didn't understand everythingh (my english is poor  :icon_frown: ).. So what it would do? switch the preset, or could I assign a preset to a channel for the use with a midi pedalboard?
iaresee
Quote from: Dimitree on January 13, 2009, 02:47:58 PM
You can use this approach to control any function on the DD-20 that can be assigned to that expression pedal. If you look in the DD-20 manual (p. 20) it says:
CTL PEDAL Jack
Connect an external control pedal (the optional Boss FS-5L/FS-5U) to this jack.
You can use the external control pedal to turn the effect on and off, to input the delay time with Tap Input, and to switch memories.
See "Setting the External Pedal Function" (p. 31)
So instead of an FS-5U footswitch you'll use a MIDI-controlled relay and you'll plug the relay into the CTL PEDAL jack on the back on the DD-20. Does that make sense?
Dimitree
ok..now I understand..thanks, and sorry  :)
in this way can I assign presets just like on the whammy? for example, when I change song preset on my midi pedalboard, the DD20 goes to preset 2, then for the next song it goes to preset 4..etc..
iaresee
Quote from: Dimitree on January 13, 2009, 04:48:11 PM
Yes, it would be possible to do this. You'd need your MIDI->relay box to know what patch you're currently on when you start up, but once it knows that you can send CC or SysEx messages to your box that indicate a patch to change to and the box can figure out how many times to latch the relay to move you to that preset # on the DD-20.
For example, if you start out on preset 1 and the MIDI message comes through to change to preset 4 the box logic has to know to latch the relay 3 times (1->2, 2->3, 2->4) to get to preset 4. If the next change is to preset 2 it needs to latch the relay 2 times (4->1, 1->2) and so on.
Dimitree
wow..that's awesome! really thanks Jarese!!
now I'll investigate how to do that.. :D the idea is perfect..thanks again!
Dimitri
Processaurus
I've had half a mind lately to try and build midi control into unlikely lo-fi suspects like fuzz pedals, I just found this place (first thing that pops up when you google "midi kits")
http://highlyliquid.com/kits/decoder.html
Processaurus
Quote from: Dimitree on January 13, 2009, 10:04:48 AM
Do you remember where, by any chance?
Dimitree
yes, once I've read (huge racks inc) that this guy on this site did that: http://clark2000.free.fr/
but strange, it doesn't list this mod, maybe you can try contact him..
iaresee
#10
Quote from: Processaurus on January 15, 2009, 06:18:17 AM
Cool site. And very cool kits. For ~$100 you're 90% of the way to making your own GigRig or Musicom or Voodoo Labs switching system with these:
http://highlyliquid.com/kits/msa-r/
All you need is some logic that changes momentary taps -> MIDI messages. My mind is spinning now at the possibilities...
