your favorite volume pot in fuzzface
Started by Mich P, January 14, 2009, 08:27:12 AM
Mich P
Hello !!
I actually rebuild my axis face from fuzzcentral.
Just for curiosity what is your favorite value volume pot
in your fuzzface.
Thanks,
Mich P.
newfish
Happiness is a warm etchant bath.
  The gain pot on the guitar is the one that gets' overlooked...
  And has a lot to do with what I like about a FF that gain controls at the guitar.
  A whole different subject.
  Much more interesting than typing about 50k, 500k and 1M FF VC pots.
  Bypass the signal lugs of big pot, the one that needs a treble bleed cap there.
  Diddle with the 330/470/1k resistor to compensate for 10k VC pot low output.
  Discuss output impedance...ughhh
  Or use 100K A.
Easywider
bluesdevil
When I experimented with my germanium Fuzz Face build I settled for 250K. To my ears the original 500k is too dark and I found 100k a bit too bright going into my Fender amp.... I like it in between.
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
yeeshkul
hmmm, i would expect that when the volume is full blast on, then 500k will be the brightest one  ???
I removed volume on my FF completely for the reasons Pete said, then i added a volume-kick switch (two different collector resistors 1k res/5ktrimmer) and put 100k back.
Mich P
Ok that's give me some ideas
Thanks for your comments.
Mich P.
bumblebee
kurtlives
#9
100K(A)
I like a 1K(C) pot for the fuzz control.
My DIY site:
www.pdfelectronics.com
Focalized
I've made many. I use 500KC, reverse audio. I like it kind of dark. A regular Fuzz Face with a normal audio pot brightens up at the last 10% of turn it seems. The reverse makes that range larger.
kierc
I had a 500KC, but I found that it boosted the volume and alot of the noise up a ton, so now I'm using a 250KA, seems alot better  :)
