Hey guys, so I built this effect, it worked great...I built one on vero board, it worked great too.
I then tried to add a bypass with a DPDT switch (just a standard bypass, not millenium) and the problems started.
The signal still gets through, and the bypass works, however there is a high pitched hum, even when bypassed, what's more, this hum increases when the gain pot is adjusted, even when bypassed.
if I touch, or earth the output (or the lug on the gain pot) the hum disappears.
I think that what is happening is that some of the signal is going back into the circuit and not the output? is this likely? should I then include a large resistor at the output of my circuit, into the bypass? is this a buffered bypass?
Has anyone encountered this problem?
I have made some adjustments to the components in the list, but I doubt these would cause such a problem.
I replaced the 1n914 diodes with 1n4148's
aslo, C2 is a 0,1uF, c3 is 27pF, c5 is 3,3nF
thanks guys.
