BTW, Valoosj, if you are concerned about space, it might be worth leaving out the threshold pot and associated circuitry. It serves as a noise gate which mutes the delay signal when the input level is low. However, there's not much noise, so I never use it on mine; the pot remains at 100 % all of the time.
Just made a few adjustments tonight to the LPF before the SAD1024A (older version) and the clock range. It's pretty easy to get the high end of the sweep so high that it affects mostly cymbals. I tried to find a balance where the top of the sweep wouldn't completely lose the harmonics of a guitar/bass signal. Because I don't have an oscilliscope, I used my DD-20 as a reference for the lowest delay time of 14 mS. Basically, I set both the A/DA clone and DD-20 with high feedback, fed them both white noise, then adjusted until the frequency of resonance was the same (~ C#).
