Author Topic: TDA1022 Flanger  (Read 94484 times)
Thomeeque
Re: TDA1022 Flanger
« Reply #100 on: February 21, 2014, 04:47:04 AM »
 Hi again, Small Bear still has it, only the link has changed: http://www.smallbearelec.com/servlet/Detail?no=495
 Unfortunately it seems little costly (it is not slide but toggle, right, so maybe that's why), type I have used sells Conrad for something like one dollar (see Mike's link few posts above). But it seems this type is sold only in Europe for some reason.
 If you would find some US common DP3T slide switch and provide dimensions, I would not mind to create alternative PCB version for it.
Will I be build # 4? :icon_rolleyes:
 Hmm, maybe there's more, who knows :) I have missed Pojo's question, maybe he has made some progress..?
 And congratulations to Mike to his final problem resolved (better late, than never :icon_redface:)!
 Cheers, T.
« Last Edit: February 21, 2014, 04:50:18 AM by Thomeeque »
Do you have a technical question? Please don't send private messages, use the FORUM!
Pojo
Re: TDA1022 Flanger
« Reply #101 on: February 21, 2014, 09:01:02 AM »
Hmm, maybe there's more, who knows Smiley I have missed Pojo's question, maybe he has made some progress..?
Nah, I haven't even begun other then glancing at the schematics and your build reports. I really really want to though! Possibly after this amp project.
armdnrdy
Re: TDA1022 Flanger
« Reply #102 on: February 21, 2014, 11:13:48 AM »
Without reading the through the entire thread to find out what the slide switch requirement is.....I have a feeling it requires a certain footprint and height because it's board mounted.
With that being said.....I've made "daughter" boards for slide switches comprised of a switch and long header pins which worked out fabulously!
fendman
Re: TDA1022 Flanger
« Reply #103 on: February 21, 2014, 11:18:03 AM »
Larry I posted the switch and where you can obtain it in Europe...all the info is on it..its page 5 about half way down  on this thread:)
Mike
armdnrdy
Re: TDA1022 Flanger
« Reply #104 on: February 21, 2014, 01:12:20 PM »
Mike
I just posted this side note as another option for the individuals that don't want to pay shipping on another order.
It seems as if no supplier has everything.....and the shipping charges add up quickly when placing multiple orders.
Think about how many components you could purchase with $6.00. (3.61 BPS)  :icon_wink:
fendman
Re: TDA1022 Flanger
« Reply #105 on: February 21, 2014, 01:56:59 PM »
[/quote]
[/quote]
Gotcha!!! Like me making onboard pots by extending the legs, cos we can't  get them in the UK and to get them it costs:icon_smile:
armdnrdy
Re: TDA1022 Flanger
« Reply #106 on: February 21, 2014, 02:11:03 PM »
Exactly!  :icon_wink:
hoffy84
Re: TDA1022 Flanger
« Reply #107 on: February 22, 2014, 03:06:24 AM »
Ya know what? That's a great idea. Didn't even think of that. What I'd really like to do is just have (4) 3-way toggle switches, but the pin config on those Euro-switches would be tricky to cross over. I have found switches that are functionally the same here in the US, but the pin spacing just doesn't.
SHAME ON YOU TOMAS, for giving us one of the best write-ups on a build that I've ever seen, and YOU putting those lousy switches in the layout!  :icon_eek:
I am kidding of course.  And LARRY, the daughter board suggestion is a fantastic idea. Do have some pics you can share?
armdnrdy
Re: TDA1022 Flanger
« Reply #108 on: February 22, 2014, 09:32:32 AM »
I don't have any batteries for my camera but this image should suffice.
This is the top view.
I used long header pins and slid the plastic "stop" where I needed it for the correct height.
hoffy84
Re: TDA1022 Flanger
« Reply #109 on: February 22, 2014, 11:16:46 AM »
Perfect. I can draw something up in Eagle like this to fit my switch. I'm etching the main and buffer boards anyway. Might as well throw these in.
Thanks for the info!
armdnrdy
Re: TDA1022 Flanger
« Reply #110 on: February 22, 2014, 11:41:43 AM »
I designed a capacitor selector box with three board mounted 12 position rotary switches to choose between 36 values of capacitance. (for testing/breadboarding purposes)
I needed a slide switch to choose between the rotary switch outputs.
I could not find a slide switch with the proper length that would mount on the board the same length as the rotary switches so....
I had to improvise.
Thomeeque
Re: TDA1022 Flanger
« Reply #111 on: February 22, 2014, 01:07:08 PM »
 I agree, that's why I am willing to create new buffer PCB variant for some common US type ;) But you must find that switch and provide dimensions.
 Only dimensions may differ, pinout should remain the same (it should not be problem, this is common principle used for 3T slide switches). And maybe try to find type with threaded mounting holes, so these can be used for mounting PCB to panel.
 T.
hoffy84
Re: TDA1022 Flanger
« Reply #112 on: February 22, 2014, 10:54:26 PM »
That would be awesome, bc I'm not going to be able to start building til a month from now anyway. I'll start looking again. I found quite a few switches that would work, but didn't bookmark the pages. I'll find one that at least 3 places stock in the US, & that are reasonably priced and post back.
Tomas  & Larry  :icon_biggrin:thank you very much.
hoffy84
Re: TDA1022 Flanger
« Reply #113 on: February 24, 2014, 09:57:52 PM »
Okay Tomas,
Well the part of choice in the US, is (drumroll) ...... The same part you referenced from Small Bear. Although it is indeed pricey, it is the ONLY switch available that has threads so that you can mount the switches to the enclosure. There were many that had mounting ears and holes. But you would need a nut on the other side between the PCB & the enclosure, and that would be physically impossible.
I checked the following MFG's: C&K Components, CW Industries, Alps, Apem, E-Switch, Switchcraft, TE/Alcoswitch.
It just so happens that the last one I checked (TE/Alcoswitch) is the only one with threaded mounting holes. I noticed that Small bear references their's as "the work-alike" of  old Alsowitch part# CST023NK, which is new TE PN# 1437576-4. I also emailed Small Bear to verify that the specs are identical, and they say yes.
Here are the specs: http://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=1437576-4&DocType=Customer+Drawing&DocLang=English
Tomas, if you feel like you have the time to change the layout for us here in the US, and it won't take too much out of you, I would be very grateful. I'm in no hurry. Just got my TDA1022 chip in today (not a knock-off) but I am still mauling through the parts list trying to source the rest of the parts.
Even though these switches are expensive, I like the "Atari Style" toggles. Maybe I'll design the pedal to look like a 2600!
« Last Edit: February 24, 2014, 10:02:44 PM by hoffy84 »
StephenGiles
Re: TDA1022 Flanger
« Reply #114 on: February 25, 2014, 03:03:59 AM »
Is the schematic of this beast here? Maybe I've missed it!
armdnrdy
Re: TDA1022 Flanger
« Reply #115 on: February 25, 2014, 03:52:40 AM »
Hey Stephen.
It was on page 3..... the last post.
http://thmq.mysteria.cz/em1022/EM1022_Build_Instructions.pdf
StephenGiles
Re: TDA1022 Flanger
« Reply #116 on: February 25, 2014, 02:09:12 PM »
Hey Stephen.
Thanks Larry, I must have skipped that page!
hoffy84
Re: TDA1022 Flanger
« Reply #117 on: February 27, 2014, 11:29:36 PM »
Question about the Cermet trim resistors:
Says to pay attention to the values in the schematic, which are as follows:
RT1   1k   CCA 50%
RT2   10k   CCA 5.5K
RT3   100k   CCA 7.0V
RT4   10k   CCA 4.7K
When selecting the appropriate trimmers, how many turns should I use? Why are the units so different (50%, 5.5K, 7.0V, 4.7K). I can KIND of understand these:
On RT1: 50% of the 1K trimmer would = 500R ?
On RT2: set the dial to 5.5K ?
On Rt4: set the dial to 4.7K ?
But on RT3, what the heck is 7.0V ? I noticed it says that one is a "Precise trimmer"
Do I need to measure the specified values with my DMM, before installing?
Not quite understanding this part of the schematic.
armdnrdy
Re: TDA1022 Flanger
« Reply #118 on: February 27, 2014, 11:42:20 PM »
Hoffy84,
Where are you reading this? Which page of the build doc.
RT1   1k   CCA 50%
RT2   10k   CCA 5.5K
RT3   100k   CCA 7.0V
RT4   10k   CCA 4.7K
hoffy84
Re: TDA1022 Flanger
« Reply #119 on: February 28, 2014, 12:41:07 AM »
Hoffy84,
RT1   1k   CCA 50%
RT2   10k   CCA 5.5K
RT3   100k   CCA 7.0V
RT4   10k   CCA 4.7K
Hi Larry,
On page 3 towards the bottom, section 4. Setup Hints - Set all trimmers as indicated on Picture 1: Main Board Schematic
Then if you look at the Main Board Schematic  on page 8, look for the RT()s. (You may go blind trying to find them, but each one reads CCA (and then the range).
Thanks! Jeff
