We have thoroughly reviewed and revised the code and have made the following refinements to our Universal Tap Tempo Control Chip MV-52:1) You can hold down the first tap as long as you like. If you hold it down more than 4.2 seconds, the chip will time out and your original tempo will be restored when you release the button. This is because the maximum tap interval is 4.2 seconds in real time.
As before, if more than 4.2 seconds elapse between the time you press the first tap and the second tap, the chip will time out and your original tempo will be restored.
2) You can hold down the second tap as long as you like. As soon as you release the second tap, playback will begin.
- What this means is you can tap in your tempo then hold down the second tap, releasing it when you are on the downbeat so you are right on time.
3) Playback always starts right after you let go of the second tap. - What this means is
you can keep tapping as much as you like, as long as it is an even number of taps, until you get the tempo you like.As before, the playback tempo is equal to the time between pressing the first tap and pressing the second tap. The release times are not part of the equation.
4) Pin 3 is the pulse output.
The Pin 2 output (the on/off, [squarewave] output), now resets after a new tempo is input so that the pin always goes high as soon as you release the second tap.The preliminary testing has shown the revised code to be every bit as accurate as before (1/1,000th of a second or better). We are going to test it for a couple more days and plan to ship replacement chips either Friday or Monday. We will let you know as soon as they ship and are once again for sale. We will also post a revised datasheet which includes these changes.
Thanks again for your feedback everyone. We have a much better product as a result of your help.
